Missing Vacuum Port?
1 Post
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Hey guys, just a question for anyone who might have had to deal with this before.
I just got a used Holley 4777 (650 double pumper) and it badly needs a rebuild. No big deal, I can do that. The problem, is that the vacuum port fitting on the carb base... i mean the small one at the front of the carb, used for things like vacuum advance... is missing. It looks like the fitting itself was pulled out somehow.
Is there a way to fix this? Or would I be better off to just plug the hole with epoxy or something and forget about it?
Engine: LS1/LQ4
Transmission: 4L60E/4L80E
You should be able to tap one back in if you find a spare of the right size. Of course, finding one the right size is why a lot of us don't throw away old carbs . . .
86CamaroDan
09-29-2015 10:08 PM
mrestrictrplate
09-21-2015 11:24 AM
toronto formula
09-10-2015 07:31 AM
