carb linkage TV and throttle stud size
1 Post
Car: 82z28
Engine: 406
Transmission: th350
what size studs do i need for the TV cable and throttle cable?
lg4 w/ holley 650dp.....200c
Car: 1987 Camaro SC, 1999 Z28
Engine: GMPP 350HO, LS1
i highly recommend the TV corrector bracket holley sells, assuming the 200c has a TV/bracket setup like the 700r4. This bracket positions the stud farther back towards the TV valve, correcting geometry if using an aftermarket carb. It should only be 20 bucks and change, and will save a lot of hassles down the road trying to get your TV correct.
Of course, I'm a 700r4 guy, and I'm assuming its basically the same basic TV/bracket setup, can't see why not.
1 Post
Car: 82z28
Engine: 406
Transmission: th350
the 200c is a 3 speed a more similar to a 350 than to a 700r4. That being set, im not sure if the 700's TV setup is the same.
damn nm, dunno what i was thinking...haha. maybe i was thinking 200r4...
I am an idiot.
I am an idiot.
1 Post
Car: 1986 Z28 Camaro Gunmetal Gray with
Engine: GM Crate ZZZ HO 350, Edelbrock head
Transmission: Rebuilt 700r4 all TransGo and Beast
Axle/Gears: 10 bolt with 3.73 gears
would this work when going from tpi to carb also? the bracket?
theshackle
09-17-2020 08:26 AM
toronto formula
11-10-2015 06:17 AM
IrocZ'85
08-17-2015 06:24 PM
knight72
08-10-2015 09:32 PM
