anybody pass sniffer w/carb?
![](https://www.thirdgen.org/forums/images/ranks/tgo10.gif)
Car: 1983 z-28/SFC/bilsteins/adj.arms
Engine: 355sbc/Demon650dp/hedmanheaders/
Transmission: t-5, alum DS
Axle/Gears: 3.42 torsen posi, baer discs
has anybody gotten a carbed 350 to pass a sniffer test? leaned jets, big cat, timing change, msd box? tell us how!!!
Car: 1984 Camaro Z28
Engine: Roller 350
Axle/Gears: built ten bolt 3.73's
Originally Posted by '86 350
Mr. Jefferson convinced my emissions guy quite nicely.....
![Roll Eyes (Sarcastic)](https://www.thirdgen.org/forums/images/smilies/rolleyes.gif)
yea, yea...mr Franklin can be persuasive, but i was looking for a real emissions test pass! anybody? would a big cat, leaned out mixture, and change in timing work?...or get close?
Car: 84 Z28 H.O. w/Megasquirt II
Engine: semi-stock L69
Transmission: T-5 non W/C
Axle/Gears: 3.73 open
Well, what you have listed is a good start.
-Fully functional ignition. You might be able to stretch your plug gap .010-.015
-Unless you have a built engine, a MSD box is probably overkill. A good coil and moudule should do your engine wonders.
-Make sure ALL emissions equipment is on. It may slow you down and seem like junk, but it is designed to help you pass these tests.
-Engine should be in full tune. That includes no vac leaks or exahust leaks.
Remember that every car is unique because it is about 20 years old. All you can do is the best you can with your setup, and bring a Franklin incase these things don't get you there.
A final option, although pricy, is to upgrade to fuel injection of some sort. TBI isn't as bad as everyone makes it out to be.
Car: '86 Camaro SC
Originally Posted by SmallTires
Pretty much the same thing here, though Mr. Franklin took charge.![Roll Eyes (Sarcastic)](https://www.thirdgen.org/forums/images/smilies/rolleyes.gif)
![crazy](https://www.thirdgen.org/forums/images/smilies/crazy.gif)
yes, but that's my point...i had efi, but went to a bigger engine for more grunt.....there IS no emissions stuff!...new efi would require more stuff, different computer, different in-tank fuel pump, etc....i want easy, cheap!
Car: 1983 G20 Chevy
Transmission: 4L60
I put a mild cammed, 350 head Olds 403 in my 1988 Cadillac under the stock Olds 307 CCC Q-Jet. With the carb properly adjusted, stock timing spec, and a good tuneup it passed the Texas dyno 50/15, 25/25 with ease.
darwinprice
17
10-11-2015 11:51 PM
