gas shooting out of carb
Car: 91 firebird
Engine: 350 vortec heads
Transmission: t5
Axle/Gears: 3.08 open diff
just installed new engine.primed oil with old distributor and as it was turning gas started shooting out of the carb.someone please help me
Car: 91 firebird
Transmission: t5
feul pressure is at 6 psi.using intank pump with 3 port regulator.i did the tbi to carb swap.
Car: 91 firebird
Transmission: t5
figured it out.when oil pressure sensor senses pressure the feul pump kicks on while im spinning oil pump.apperently the feul pressure is too high needle stuck.i didnt know 6 psi was too much
Car: 91 firebird
Transmission: t5
new problem
new problem.how do i fix the gas from shooting out carb.i dont think 6psi is too much.is something broken or just needs to be cleaned?
Car: 91 firebird
Transmission: t5
the overflow tubes.dropped pressure to 4 psi and it quit.maby one of the floats is way off cause my buddy came by after i got it cranked and was tuning carb and seen one of the floats was way off
Car: '83 Berli, '84 Berli, '84 Z28 HO
Engine: L69, LG4, L69
Transmission: TH700-R4, TH700-R4, T-5
Axle/Gears: 3.08, 3.08, 3.73 Posi
more than likely your floats were not adjusted right, or your needle/seat was stuck open... it happens.. if it was a brand new carb. i would say Floats.
350, carb, carberator, carborator, carburetor, coming, engine, gas, heads, oil, overflow, shooting, shoting, shotting, spitting
