Close up picture of V8 carbed Evap canister and lines
Car: 2000 BMW M5
hi guys, can someone with an 83 or 84 (85 will probably also work) 305 4bbl take a picture of their evap canister and the lines coming out of it? I am nearly done with my V6 to V8 swap. The V6 used a remote electric purge solenoid, but the V8 uses the vacuum can attached to the front of the Qjet to purge the can without any solenoids. I am not sure if the V6 and V8 use the same evap canister or if they are different. Your picture will help me figure it out! THANKS!
1 Post
Car: 87 Camaro Z-28
Engine: 305 LG4 w/ E4ME carb
Re: Close up picture of V8 carbed Evap canister and lines
maro man, I found your older post - do you still need pictures? scooter
Car: 2000 BMW M5
No I am waaaay past that point, thanks anyway though. I am ready to throw the whole CCC system in the trash after painstaking troubleshooting with it, since my 2006 posts. I fully understand why the LG4/CCC system has such a bad reputation. It really does deserve it.
