intakes
Old 04-06-2006 | 12:39 AM
85blackberlinet's Avatar
Car: 85 berlinetta
Engine: none
Transmission: 700r4very soon t5
intakes
what do i have to do to get my carb in take on a tbi motor
Old 04-06-2006 | 11:25 AM
five7kid's Avatar
Engine: LS1/LQ4
Transmission: 4L60E/4L80E
Depends upon the intake you have.
What do you have?
And, is the intake all you're asking about, or do you mean the whole carb set-up?
Old 04-09-2006 | 10:52 PM
Car: 85 berlinetta
Engine: none
its an old weiand intake and a 750 holley dp
buying fuel pump,distributor just i heard something about some bolt holes might have to be withered out
Last edited by 85blackberlinet; 04-09-2006 at 10:55 PM. Reason: Automerged Doublepost
Old 04-10-2006 | 10:29 AM
five7kid's Avatar
Engine: LS1/LQ4
If you still have the TBI heads, the bolt angle of the center two intake mount bolts on each side will be at a different angle than the rest. Elongate the holes in the intake manifold until the bolts will start. If you're really ambitious, you can find some angled washers to go under the bolt heads.
Old 04-10-2006 | 12:05 PM
Car: 85 berlinetta
Engine: none
thank you
customblackbird
10-01-2015 04:30 PM
85 Jimmy
09-30-2015 07:56 AM
jerflash
09-24-2015 03:11 PM
toronto formula
09-10-2015 07:31 AM
e3pres
09-09-2015 01:51 PM
Quick Reply: intakes
