what is the best carbon cleaner that is ez on carbs
Old 04-04-2006 | 12:30 PM
z28z34man's Avatar
Car: 1984 z28 camaro / 2019 accord sport
my car has been running rich since i got my demon. i got it pretty much tuned but there is a carbon build up from when it was running rich. what would be the best carbon cleaner that wont damage carbs.
Old 04-04-2006 | 12:52 PM
z28z34man's Avatar
would half a can of sea foam threw the vacuum be too harsh
also what jets would you recommend now i have 74 pri 81 sec that helped a lot from the 76 pri 83 sec
Old 04-04-2006 | 05:55 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
that'll work. 1/3 can is what it says on the label though. throw a third in the gas tank, then do a third through the intake. save the last 3rd for a rainy day, or put it in your crank case (oil).
Old 04-05-2006 | 12:19 AM
MillerTime21's Avatar
Car: 94 25th TA
Engine: 355LT1
Axle/Gears: 10bolt 3.42
I have the same problem, what is sea foam and where can I buy it?
Old 04-05-2006 | 12:06 PM
z28z34man's Avatar
how about Chevron TECHRON Concentrate Fuel System Cleaner i heard that was some good stuff
you can get sea foam at any part store
Old 04-06-2006 | 05:25 AM
jstoltz's Avatar
Car: 1987 Iroc-z Convertible
Berrymans stuff is the best I've found so far.
Old 04-06-2006 | 10:29 PM
Rick King's Avatar
Car: 1987 TA
Engine: 350 stock/twecked
Tranny fluid will clean and lube the upper part of the heads really well, only wse a little bit like 3 oz to 10 gallons of gas. I have also had great luck with seafoam and Berrymans
later adn gb
rk
Old 04-07-2006 | 12:25 AM
F-BIRD'88's Avatar
Car: 1988 Firebird S/E
Engine: 406Ci Vortec SBC
By spraying stuff down the carburator,
You risk washing the oil off the cylinder walls and rings which will scuff the rings.
Just go buy a new set of spark plugs and take it for a ride and blow the crabon out of 'er. then replace the spark plugs.
Ive found that nitrous oxide does a fantastic job of "decarbonising" the combustion chambers. A small 100hp shot will surely clean 'er out. Again, replace the spark plugs after. You have to replace the spark plugs cause all the carbon that gets blasted off the piston tops fouls the plugs.
Plain old water (water injection) will steam clean the combustion chambers spotless, but must be injected while the motor is at mid/high rpm 3000+ and at least partial load. Like when cruising down the hiway at 60+MPH.
A simple windshield washer pump and squirter setup is all that needed.
be sure to put a NOS fuel solenoid in the water injection line to avoid siphoning. You can control the amount of water flow by adjusting the voltage to the pump. Water (steam) will work better than any chemical product. Only a small amount of water needs to be injected, but requires time (a good drive on the hiway) to work. Take a spark- plug wrench/socket and a set of new spark plugs with you.
Old 04-07-2006 | 11:07 AM
z28z34man's Avatar
i planed on getting new plugs after the carbon cleaner. i also want something that will work on the o2 sensor
Old 04-08-2006 | 02:28 PM
F-BIRD'88's Avatar
You can clean (remove the carbon buildup) from a O2 sensor by removing it and burning the tip with a propane torch. Will be a gray colour when you're done.
This will not fix a faulty o2 sensor but can/will fix a "lazy" one caused by the carbon buildup.
Old 04-08-2006 | 02:52 PM
z28z34man's Avatar
the o2 sensor is about a month old it should still be good i think it is a little off because it reads a little rich not even running
Old 04-09-2006 | 10:03 PM
rideon1200's Avatar
On Probation
Car: 2002 Formula
Engine: 5.7 LS1
Hey just a quick thought. In the Goldwing site EVERYONE swears by MMO. They use it at every fill up, dont use too much or it will smoke. Seems to remove deposits from carbs, keeping them clean. I used to use it, did run better after just one tank. They also use it about 100 miles before oil change, cleans out sludge.
Old 04-10-2006 | 12:37 PM
1991L98G92's Avatar
Car: 91 Z28 24th Anniversary
Axle/Gears: Posi 3.23
Go down to your local GM dealer and get a can of X-66. If available, get the X-66A (aerosol). Spray to your hearts content down the throttle while running. Do this in an open area, engine will smoke. "Best stuff in the world".
Old 04-13-2006 | 11:26 PM
greggbruce's Avatar
Car: 84 454 monte, 89 formula, 86 camaro
Engine: the bigger the better
Transmission: 700/4L60 in everything
Axle/Gears: wish they were all 4.10's or better
never heard of x-66, but have heard of gm top engine cleaner, both aerosol and liquid.
that is the BEST I have found in the last 25 years.
CONKLIN 4 power is the best in tank additive I have found in the last 25 years. run it 4 times a year
Conklin Company Inc., then find a distributor near you.
ATF is NOT good for o2 sensors, but is a good carbon remover. same with antifreez. water is a very good carbon remover, but only in the combustion chamber, it obviously won't get the carbon off the carb and out of the passages. get the aerosol gm top engine cleaner.
Old 04-14-2006 | 12:47 PM
1991L98G92's Avatar
Top Engine Cleaner is X66. It's the stock # or item #. If you ask for X66(A) they'll know what your talking about.
Old 04-14-2006 | 09:58 PM
greggbruce's Avatar
I just looked at the 2 cans of gm top engine cleaner at my shop and neither of them have "x66" on them anywhere.
I've been in gm dealers since 1989, and have never heard of it called "x66"
doesn't matter..... it's still the best stuff.
GeneralIesrussi
Carburetors
06-20-2024 08:21 PM
PurelyPMD
05-05-2016 05:57 PM
bbsr72
04-02-2016 10:12 AM
codeysabatini
11-10-2015 05:07 PM
budowski
Carburetors
10-02-2015 11:16 AM
