AED "Eliminator" Carbs
Car: 85' Z28
Engine: 383 roller
Axle/Gears: Ford 9" 3.70
Has anyone run these? I'm basically comparing these to a speed demon. My main concern is that it may not be big enough. I'm runing the 355 for a bit, but hopefully by mid summer I'll hvae the same top end as in my sig, but with a 383 shortblock and a fairly large cam.
1 Post
Car: 86\92 Mutant
Engine: 355CI 430HP
Transmission: T-5 with mods
Axle/Gears: 7.625", Eaton Posi, 3.73
AED makes very nice products. Not sure what you mean by " Eliminator" carb as it does not seem to be listed on their Web Site.
http://www.aedperformance.com/
I'd think a 750DP should be more than adequate for both the 355 and the 383.
Car: 85' Z28
Engine: 383 roller
This was the one I'm talking about. "Our new "Eliminator" carburetor is designed for 302-360ci engines in heavier cars or with tight converters. It features a CNC ported 650 main body mated to an 850 baseplate for good airflow for power, but smaller venturi sizing for exceptional acceleration. One Killer carburetor for small block Fords." http://www.aedperformance.com/SupMod.htm
Thanks, I think I'm gonna have to pick one up
1 Post
Car: 86\92 Mutant
Engine: 355CI 430HP
Why don't you call AED Tech support and ask for their recomendation? They are very friendly and knowledgable from my experience.
BTW, going with a custom mfg like AED is certainly a bonus as they will setup the carb to your specific cars use and specifications BEFORE shipping it to you. Much better than buying an "off the shelf " unit from Holley or even Demon. And you get a custom tuned and prepped piec that is the same price or even cheaper than a comparable Holley or Demon product ( in most cases ).
AED
RedLeader289
05-28-2019 01:47 PM
FueledSoul
09-29-2015 08:58 PM
efiguy
09-27-2015 01:30 PM
