carb to tbi wiring?
Car: 91 firebird
Engine: 350 vortec heads
Transmission: t5
Axle/Gears: 3.08 open diff
tbi to carb wiring?
ok,i have a few questions about the tbi to carb swap that i normally dont see.first off,what is the best way to remove the factory harness?which sensors do i keep for my dash guages?do i just remove the split loom,trace those sensor wires and simply cut off everything that i wont use at the firewall.
second:will my ac still work after i make the swap?
third:will my fan still kick on at the factory preset of 220 degrees?
