what would cause excess fuel dripping from only one venturi
Car: 87 formula and 85 olds delta 88 2 d
Engine: 60's 350 holley carb and intake
Transmission: muncie 4 speed with centerforce
Axle/Gears: 3.42 99 camaro rear w/ discs
edelbrock 600 cfm. i am having idle issues..sounds like its hunting. so i looked down the carb while running. one venturi is kinda dry and the other side is dripping globs of fuel. and my jets are the same rods same springs same and the idle screws dont do anything when it comes to the fuel dripping? dirt somewhere?
nope still need help...looks like even under part throttle that one passenger side main venturi is just drooling liquid gas all over the throttle blades. while the other is pretty much bone dry. checked and re-checked jets, springs, needles and all the same. floats are hanging the same. no dirt anywhere? its a edelbrock 600 #1406. please help..
can you get to those air bleeds for inspection? i know there is a 1st air bleed and a 2nd air bleed from edelbrock's web site pictures.
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
They come out with the whole booster assembly, you can inspect them and clean them pretty easily.
WHERE ARE THEY? HOW DO I GET TO THEM? FROM UNDERNEATH (REMOVING CARB OFF INTAKE?) something has to be clogged.
Engine: 383 Carb
Transmission: 4L60
From the top. Take the top of the carb off, the boosters are each held in by a pair of torx screws. Pull them out and flush all the brass tubes sticking out of them with carb cleaner and compressed air.
ok i did that yesterday and no help.i will try again. edelbrock is asking me about fuel pressure and float height.i think there juggling me
yeah i got it running well. little piece of something in the air bleed. what a difference a little tuning does. now i pass everything but a gas station...
92camaroJoe
08-13-2015 06:07 AM
