tv bracket
Car: 1987 iroc z
Engine: 355 dart platinum 215cc heads
Transmission: <<BLOWN UP TH400>>
Axle/Gears: 10 bolt 4.11's
tv bracket
ok i got a holley 4777-2 carb and i am doing a tpi to carb swap and need to know the the part # is for the throttle and tv bracket thanks.
Car: 92 Camaro
Engine: ZZ4 Crate Engine w/Hot Cam
Transmission: Rebuilt 700R4 with Transgo and MW 3
Axle/Gears: 3.73 Eaton Posi
Go to www.bowtieoverdrives.com
They have a perfect bracket for adapting the 700R4 to the holley carbs.
It is costly (way more than the simple brackets in summit racing) but it works GREAT. I tride the cheasy TV bracket from summit. Big waste of $20.
