Q-Jet Getting "Stuck"
Car: '83 Trans Am
Transmission: TH350 w/2500 stall
My Quadrajet carb on my 83TA (with a 350 Chev and TH350 trans with 2500rpm stall) has recently started getting "stuck".
When I start up, it revs up quite highly to over 3000rpm and then slowly descends.
When driving, sometimes it hold the revs after throttle and I have to brake to reduce the revs.
I had a look at what the carby is physically doing, and the part that turns when applying the throttle (excuse my lack of knowledge) isn't turning back.
There are two linkages, a spring and the throttle cable.
What do you think is the problem? Is it the linkages or perhaps a vacuum issue? From my understanding there is a vacuum from the transmission to the carby?
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
I had a similar issue before, turns out the secondary throttle tang was bent a bit, so that when I went into the secondaries, they wouldn't close on their own, so it'd hold the rpm up about 1k or so, until I blipped the throttle and it snapped back, or I hand turned it shut. Just had to rebend the tang.
the part that turns when applying throttle can be called the throttle arm, or linkage...
I definately think it's a linkage issue of some sort. Does the throttle return have a dual spring?
Car: '83 Trans Am
Sonix, I thought it would be to answer your question with a picture (attached). I have highlighted a part which looks suspect, this may be what your eluding to. Perhaps I need to tighten this? (if so how is it done?)
Would lubricating any of these parts (with carb cleaner spary) help at all?
Car: 1982 Trans-Am
five7, you've confused me, what are you talking about? referring to me?
I had a problem with the yellow circle area. That rod pointing upwards was bent a bit too far backwards. Probably not your problem here, but thought i'd mention it.
The area you should look at is with the green arrow. That's your primary throttle linkage.
the thing you circled I think is the cruise control slider dealy. Maybe someone can confirm/deny this, but I think I remember removing that....
the linkages aren't meant to be lubricated, as oil/grease whatever, just tends to attract dust, and act like a liquid sandpaper, roughing up the moving parts. Carb cleaner wouldn't lubricate it, but would clean it, maybe you could try that. Most are brass, and have nice bearing surfaces on them, just need to be clean.
You can try a squirt of wd-40 though.
Engine: LS1/LQ4
Transmission: 4L60E/4L80E
Ah, gotcha. Now I know what you were talking about (I thought it was the lock-out tang).
9 times outta 10 the problem is what Vader said- worn out throttle shaft bushings. GM liked to have the throttle cable and the return spring both pulling in the same direction (backwards) on the QJet. Nice for a clean, space-efficient design, but hell on throttle shaft bushings. A simple switch of the throttle return spring to the top of the throttle arm (not the bottom, like stock) going FORWARD to a spring bracket can often eliminate 80% of all throttle shaft wear on a Qjet. It can even eliminate the problem you are having now, even if your throttle shaft bushings are already shot.
Problems:
1. Not mucdh room around the stock air cleaner to have the spring up top/in front of the throttle arm.
2. No bracket to attach it to up front- have to make one yourself.
Problems:
Car: 1999 Pontiac T/A Firehawk
Engine: ***'s Engine
