linkage issue
Car: '86 Trans Am
Engine: stout 350
Transmission: automatic
linkage issue
Yay it started. After working on it all weekend, my car started with the enw motor in it. But now it idles really high. Since I got a Weiand stealth intake manifold (would reccomend getting one, seems that none of the stuff fits right) anyway, the linkage seems to sit about a 1/2 inch too far back, making it idle aroud 1700. Anyone got a remedy for this, my dad said hes gonna bend it, but i was hoping someone had a better solution than that!
Engine: LS1/LQ4
Transmission: 4L60E/4L80E
Check Summit or Jegs for an adjustable bracket. You may be able to find something locally if you have a decent speed shop in your area. The chain parts stores probably won't have the quality hardware you'll want.
Engine: LS1/LQ4
To be more specific, check www.summitracing.com for p/n SUM-G1414. It mounts to the carb base.
Car: '86 Trans Am
Engine: stout 350
any other suggestions
yea, thanks for the input but that adjustable bracket wont work for my 700r4 tranny, says so in the compatability profile. Any one else got any ideas???
Engine: LS1/LQ4
Sorry, I was looking at several brackets after searching their site and confused that one with others that say they will.
Try your own search on Summit for throttle cable brackets.
Car: '86 Trans Am
Engine: stout 350
how bout this one?
doe sthis linkage have all the right holes and stuff for my car SPE-2428 , I dont remember how many cables were runnin through there, and I cant really look at it for another few weeks. thanks for the help in adavance!!!
