which distributer
Car: 86 iroc. white.
Engine: goodwrench 350 (stock for now)
Transmission: monster trans 700r4
Axle/Gears: 2.73 ( want 3.73s , gimme a holla)
which distributer
bought a 1405 edelbrock permormer carb. got the adapter plate for it. i just need to get a distributer. anyone have recomendations/ links to summit. i cant find exaclty what it is i need. all i see are upgrade kits and caps. thx
Engine: LS1/LQ4
Transmission: 4L60E/4L80E
Originally posted by 86irocmike86
links to summit.
links to summit.
Search on "HEI", then on part type, click on "Distributors", "Chevrolet", "V8", "Vacuum and mechanical".
1 Post
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
I'd suggest an MSD distributor. They make one thats a drop in replacement and does not require an ignition box. Its made to replace both the old points distributors and HEI distributors as well. Unlike HEI, this distributor uses an external coil, so you need one of those as well, and find a place to mount it.
The MSD part number is 8360
my bad...
sum-850001r
sum-850001r
1 Post
I still think that MSD distributor would be a great one for you to use. You can check it out at Summit with p/n "MSD-8360"
There are two... you dont want the marine version.
Engine: LS1/LQ4
my bad...
my bad...
sum-850001r
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
The SUM-850001R is probably a better deal for the price. The MSD is good but it's hard to justify spending twice as much for it and then you still have to buy a coil.
thanks for the help guys. i totally forgot about the distributer until after i ordered the other stuff ( carb and spacer). now all i have left is to order my headers, then im doing the carb swap and the full exaust from headers back swap. i cant wait, should get some good gains. i could have just rebuilt the quadrajet but for future the non CC carb will be nice to have to get a cleaner engine bay and whatnot.
PS - its a goodwrench 350, formally an LG4 . the new exaust alone should be killer.
PS
dont i need an inline fuel filter too? ive been told the rochsters have the fuel filter built into it, whereas the edelbrock does not. thanx
Car: 1984 Trans Am
Engine: Vortec 355
Transmission: TH-700R4
Axle/Gears: GM Axles and GM 3.73
yah you will need an inline filter......i think that all aftermarket carbs require an inline filter....i know that edelbrock and holley do for sure....
1 Post
Look up a fuel filter for a '69 Hemi Charger... that uses an inline filter thats fairly small, but flows well enough for a pretty healthy SBC.
Car: transam, el camino
Engine: 415
I bought the summit brand HEI w/ polished housing and the shaft seperated from the rotor mount! It was a royal pain to diagnose the problem and I ended up replacing the coil and module before gettting it figured out. They wouldn't help me out because it was past the 90days warrenty so I'd reccommend the msd, mallory, or upgrade a used hei from the junkyard before buying the summit brand.
Engine: 415
You might be fine with yours though, someone probably just fell asleep on the production line and every company gets quality control problems.. if you ever get an intermittent timing problem you'll know what it is!
Gunner242
12-25-2015 04:49 PM
drptop70ss
10-04-2015 09:44 PM
