Mallory MAA-4309 AFPR
Old 11-12-2005 | 01:08 AM
parks911's Avatar
Car: 91 Camaro RS
Engine: 350 Police with some MINOR modifica
Transmission: kitted 700R4 & vette servo
What other parts should I be needing when I buy the MAA-4309 AFPR?
I'm wanting to have everything sitting here before I realize I didn't get what I needed?
Fittings?
Fuel lines?
Gauge?
Give me part number if available.
Old 11-12-2005 | 02:00 PM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
3/8" npt fittings to whatever size -AN line you're running, typically it's -6 to the carb.
Old 11-12-2005 | 04:55 PM
parks911's Avatar
Car: 91 Camaro RS
I've got to looking.
My return line is 3/8 & to the carb is 5/16.
According to summit racing that will make my return a -06 & my feed a -05.
I am able to find the appropiate fitting for the AFPR to my return line, but it looks difficult to find the right fitting for my carb feed line.
Old 11-12-2005 | 06:25 PM
parks911's Avatar
Car: 91 Camaro RS
How bad will it hurt my fuel system if I went with a 1/4 inch (-04 an) feed for my carb?
I know that I have to keep the return larger then the feed & that is what I'm trying to do.
Old 11-12-2005 | 07:17 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
What carb?
Old 11-12-2005 | 07:24 PM
parks911's Avatar
Car: 91 Camaro RS
Originally posted by Stekman
What carb?
Holley 600 CFM
Old 11-14-2005 | 01:05 PM
five7kid's Avatar
Engine: LS1/LQ4
Transmission: 4L60E/4L80E
That sure sounds backwards. The larger line should be the supply.
Old 11-14-2005 | 09:40 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
There are special adapters (single or dual feed) for -6 AN to the holley inlet fitting size or whatever size feed line you are thinking of.
norcalz28
Northern California
26
12-07-2016 01:49 PM
2012sergen11
10-13-2015 08:38 PM
Reid Fleming
10-10-2015 10:56 PM
alpine247
09-16-2015 06:25 PM
355tpipickup
09-04-2015 06:32 PM
