Holley 670 linkage
Car: 1987 Z28
Engine: Tree Fiddy (modded)
Holley 670 linkage
So I just installed my new intake and carb, and now im left with 3 linkages I have to hook up....what are all of these?? Can someone please tell me where they all go so I can get my car running Also on how to adjust the tv cable so i dont fry my tranny.
A picture would be great, possibly with labels of there these things go
thanks in adavnce
thanks in adavnce
Engine: LS1/LQ4
Transmission: 4L60E/4L80E
The top two cables are the throttle (connected to the accelator peddle) and cruise control. The bottom is the TV cable.
There is a kit that gets the geometry right for the TV cable. I don't recall off the top of my head where to find it, but trying www.summitracing.com is a good place to start.
Attaching the cables to the throttle arm can be accomplished with studs, which I know are available from Holley and Summit. Brackets to hold the cable housings, same.
Car: 1984 Trans Am
Engine: Vortec 355
Transmission: TH-700R4
Axle/Gears: GM Axles and GM 3.73
yah i dont have the cruise control hooked up on mine right now......im assuming you have a street avenger 670.....holley makes a bracket that sets the throttle cable and tv cable in line and hooks right up to the carb.....i set my TV cable the usual way, by racheting it all the way in then going WOT, allowing it to rachet out as far as it needs.....i haven't had any problems so far.....
good luck!
good luck!
Car: 1987 Z28
SO this is what i did
i pulled the throttle WOT, and I pressed the little D looking button on the cable and it like slacked while i did that.....did i do this right???
Car: 1984 Trans Am
Engine: Vortec 355
you press in the little D shaped piece and push the racheting part all the way in (towards the bracket).....then you let off of the D shaped button and then pull the carb to WOT....this should make it rachet out as far as it needs to go......this
site explains it in more detail.....
Car: 1987 Z28
sorry sorry sorry, but Im dumb and still dont get it.....
Heres what im getting out of it:
1) you hold the D button, and move that little slider all the way to the braket?
2) you let go of the d button and your done?
sorry, but its just all weird to me.....if thers a like a "tv cable for dummies" book, let me know....lol...
Car: 1984 Trans Am
Engine: Vortec 355
once the slider is all the way in you pull the throttle to WOT and it should rachet out the slider to the correct position.....
RedLeader289
05-28-2019 01:47 PM
Royal_Z
09-30-2015 08:45 PM
