Holley and Throttle Kicker
Engine: LS1/LQ4
Transmission: 4L60E/4L80E
From www.summitracing.com :
HLY-46-74 Universal Throttle Solenoid $67.39
HLY-20-9 Bracket $7.88
HLY-26-57 Solenoid Nut $4.99
What do you mean by "electrical"?
Electrical hook up. The throttle kicker was a problem before the motor swap. The solenoid would bump the throttle up with air con on but never 'releash" when the A/C was turned off--actually it was powered all the time. I was wondering if I could simply wire the solenoid directly to the A/C (without a relay) so that I could control power.
JamesC
JamesC
Engine: LS1/LQ4
Oh, yeah, I remember now.
The relay helps control the power going through the switches. It would be nice to locate your sneak circuit, or just rewire the thing and keep the relay.
I was hoping to go straight from the green to blue wire:
http://www.geocities.com/vtcamaro/Pi...rams/pg145.jpg
In-line fuse?
JamesC
In-line fuse?
JamesC
86CamaroDan
09-29-2015 10:08 PM
