What throttle linkage for the Street Avenger
Car: 87 Trans Am
Engine: now a 350
Hi,
I put the Holley 670 cfm Street Avenger carb on top of my Edelbrock manifold and I want to make sure I get the correct brackets to hook up my throttle and the 700r4 kick down cable. And also the cruise cable. Part numbers would be awesome.
Car: 87 Trans Am
Engine: now a 350
Maybe I should also mention that the car is a 87 Trans Am and the original intake was a carb so I have the stock carb bracket but it looks like that bracket will not work.
Car: 87 Trans Am
Engine: now a 350
so are the part numbers from Jegs 510-20-44 and 510-20-121? And will I be able to hook up the cruise control cable to them too?
Car: 87 Trans Am
Engine: now a 350
This is the only thing I waiting on before I can start the car. I'm tired of buying the wrong part!!
Car: 1982 Z28
Engine: 355
Axle/Gears: 12 Bolt
My buddy runs the bracket #510-20-95 and #510-20-121 on his 88 T/A with Holley 4150 SBC and 700r4.Had to run both for the 700r4.
Car: 1984 Trans Am
Engine: Vortec 355
Transmission: TH-700R4
Axle/Gears: GM Axles and GM 3.73
i have the 670 street avernger and i use the bracket on that site that is labeled "E" and it hooks up my throttle and kickdown for the trans
86CamaroDan
09-29-2015 10:08 PM
