Open Element or Dual Snorkel
Car: '90 RS
Engine: Vortec 350
Axle/Gears: 3.23 non posi
Recently bought an 85 Z-28, I wanna do some mods to it so im gonna start with the intake and exhaust. Im kinda in a bind though. Ive searched the forums and found that dual snorkels and open element are both good options. My question is, is one better then the other(performancewise)? Also, with the open element, do you need a cowl hood induction or scoop? Thanks in advance
Car: '90 RS
Engine: Vortec 350
Ok thanks, now would it be ok to keep the stock hood on for an open element or would it be useless bc its just sucking in hot air?
Many people run an open element with the stock hood--my guess is that more members do that than anything else. Here's mine, for example (I used to run a dual snorkel on my LG4):
https://www.thirdgen.org/techbb2/sho...hreadid=314726
JamesC
JamesC
Car: '90 RS
Engine: Vortec 350
Ok, thanks for your help, im going to go with the open element. Would the best place to buy the filter from and the other stuff be at summit racing? or are there cheaper places?
Car: '90 RS
Engine: Vortec 350
Ok thanks, one more question, would clearance be an issue if i got a 3 in filter? Or should i just play it safe and get a 2.5 in. Is there that much of an airflow/performance difference between 3in and 2.5in? Thanks
You'll probably have to experiement to know for sure about fit. My car has poly motor mounts and as a consequence the motor sits up a bit and the 3 in. won't fit. If you have stock mounts, especially if they've collapsed some, the 3 in may well fit. More flow, the better.
JamesC
JamesC
Car: '90 RS
Engine: Vortec 350
edit: one more question. will the tech article titled "TBI Open Element Installation" work for my engine, i just wanna double check before i start anything, i was wondering bc it says tbi, and i got a carb
Car: 83 Z-28
Engine: LG4
Axle/Gears: 02 WS6 Rear w/3:42
A 3 inch filter will fit under the stock hood. Just make sure its a drop base and you will be good to go. I wouldnt follow the tbi tech article because their installation is a little different. All you really have to do is plug the vacuum line that goes to the stock air cleaner, take off the metal tube that comes out of the drivers side manifold, and then you can put the open element on. I would also get a push-in breather filter to replace the silver breather tube.
Engine: LS1/LQ4
Transmission: 4L60E/4L80E
Re: Open Element or Dual Snorkel
Originally posted by Frozer!!!
... is one better then the other(performancewise)?
I'm only saying this because I've been there, done that.
Car: 87 Z28 Hardtop
Engine: 305ci-4bbl
Transmission: 700R4...3.27 posi being installed
Now i bought a dual snorkel air cleaner but the passenger side snorkel hits this plastic contraption thats on the hose from the intake manifold to the heater core in the firewall. can i get more hose to move it out of the way so i can put my air cleaner on or am i screwed?
Car: '86 Camaro, '85 Z28, '92 Firebird
Engine: LB8 2.8, LG4 5.0, LO3 5.0
Transmission: TH-700R4, T-5, TH-700R4
Axle/Gears: 3.42s, 3.23s, 2.73s
I would stick to my dual snorkel intake if I could, but my new holley carb hits the base of the air cleaner, and I doubt I can raise the air cleaner to clear it because my intake sits so high as it is. I "borrowed" the air cleaner off of the '69 Stingray in our driveway for the time being, but the size of that air cleaner is unbelievibly small and I doubt its helping out the air flow (and this thing was used on top of a 427! Hard to believe). So is the vent from the valve covers really not that important to have running to the air cleaner?
Car: 1993 Nissan 240sx
Engine: Turbo KA24DE
Transmission: 5 spd
Axle/Gears: 4.08 VLSD
You know you can get fiberglass things that go over open element filters of all sizes and they have 1 or 2 3-4" holes in them to connect to a hose (or hoses) to route cold air to the element, right?
My plan is this: I have an open element. I intend to cut the back of the hood, between where it rolls under and goes down to seal with the cowl. Then I want to weld some mesh to the inside of the holes, remove my hood insulation and replace it with some newer, thinner stuff and cut it so air can still get in there, and bam, instand cheap sleeper cowl induction.
Engine: LS1/LQ4
jer4251
09-27-2015 09:52 PM
IROCZDAVE (88-L98)
09-02-2015 08:49 AM
IROCZDAVE (88-L98)
09-02-2015 08:43 AM
