Pressure dropping while driving
Car: 1982 Z-28
Engine: 383
Transmission: Turbo 350
Axle/Gears: Det. Posi, Superior Axles, 3:73 G
I have a HT383 with a Carter Street pump and while driving the car will start up with 6si and drop to 0...yet the car still is fully responsive and gas is still coming out. I took out the charcoal canister and took out the electric fuel pump and plugged the return. Any idea why pressure drops but the car still runs fine?
All gas lines are fine and filters are brand new.
Car: 89 Formula Firebird
Engine: 357
Transmission: turbo 350, EDGE 3500 stall
Axle/Gears: GMPP Dana 44, 3.73 gears
did you ever find a cure??? my 89 formula is set up the same way and doing the exact same thing and I cant figure it out
Engine: 357
mine is mounted on the rail and is an autometer. Ive also tried 2 liguid filled jegs gauges. Ive tried 2 carter p4601hp pumps, 3 regulators, re routed my fuel line. the pump will build 7 psi and sit there and idle and slowly drop to 3 psi then come back up to 7 then drop until it finally hits 0, and dies. It will do this while driving down the road. The line stays decently cool but the pump body gets hotter than a firecraker when pressure drops off. Anyone please help, a friend of mine has a 75 camaro and is suffering similar problems. What gives????
Car: 1982 Z-28
Engine: 383
five7kid - I have an Autometer Liquid Filled guage that is mounted within my cowl hood. I also have a small jegs one in the fuel line.
The car runs fine, it does not die and still remains all it's power.
When it first gets started, it'll hit 6-7psi...then it'll slowly fall to zero..after some miles of driving.
I did remove the charcoal canister and I have that line running by my left front tire. I do smell the gas fumes...could the pressure be coming out of that?
Also I read to get rid of the sealed gas cap and get a vented one. Which model would fit our necks of the tanks?
knj8 - my fuel pump and line are all new and the motor runs fine. Also my fuel pump does not get hot.
Engine: LS1/LQ4
Transmission: 4L60E/4L80E
Stant 11822 & 11823 are the gas caps that fit our cars. One is vented, the other is not, but I don't recall which is which (I think the 11822 is vented). The card says vented or non-vented on each one. I doubt that's your problem, but if you don't have the charcoal canister you should cap off the vapor line and use a vented cap.
Although it sounds like at least one of your gages is away far enough, reports are the gages indicate lower pressure when they get hot. My Spectre doesn't, but I don't really rely that much on it.
Car: 1982 Z-28
Engine: 383
Since I converted from electric, in tank pump removed and small pickup line installed, and put on a mechanical, could it be that if the mechanical senses the holley carb bowls are full and does not force gas toward the carb?
Engine: LS1/LQ4
The fuel pump "senses" fuel pressure, not bowl filling. When the carb isn't requiring flow, i.e., the floats have closed of the needle valves, the pump simply doesn't produce any more pressure than the 6-7 psi in the line between the pump and carb.
Engine: LS1/LQ4
If it falls to zero, it means either the pump isn't pumping, or there isn't any resistance to flow.
Car: 1982 Z-28
Engine: 383
five7 - I did some research and it's vapor lock. I've been reading some posts on here. How can I hook up a return line with my setup? Can I put a "T" in the line after the mechanical pump? The "T" going to the return?
I'll get an electric pusher pump also...but I got a chrome Holley Fuel line to the Carb...so I was wondering on the return line set up. Any tips? Thanks.
Engine: LS1/LQ4
The threads on vapor lock pretty much went over the options.
Pusher pump is the easiest way to avoid it. Return style reg is the simpliest way to regulate pressure and provide a fuel return.
Car: 1982 Z-28
Engine: 383
Thank five7 for all the help, I'll look into the Mallory or another bypass regulator and try the pusher style pump.
92camaroJoe
08-13-2015 06:07 AM
