Idle-Mixture settings, idle RPM's, and manifold vacuum
Car: 1987 Camaro Z28
Engine: 5.7L, L98 slightly modified
I have an 87 L98 that I just put a single plane intake and Holley 600 double pumper on. The engine has headers and 3" exhaust with a Flowmaster and no cat (other than that it is stock). I was using a vacuum gauge to set the idle-mixture on the carb, and the instructions I have say to use an idle speed of 850 RPM's and adjust the idle-mixture screws and idle speed screw to achieve highest possible vacuum @ 850 RPMs. Using an idle speed of 850 RPMs I can get a steady reading around 20" of manifold vacuum. The stock setting for idle speed on a L98 is either 500 or 600 RPMs. When I adjust the idle-mixture screws to get an idle apeed of 500 RPMs, manifold vacuum drops to a steady 15".
I know the engine is running good internally because the vacuum reading is always steady. My question is which idle speed and vacuum setting should I use: 20" @ 850 RPMs or 15" @ 500 RPMs? By the way my timing is set at 6* BTDC.
Thanks in advance!
Thanks in advance!
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
since you don't have a radical cam, i'd go with around 600rpm or so. You don't need more then 15" I wouldn't think.
Car: 1985 Camaro Z/28
Engine: L69
Axle/Gears: One-Wheel-WOnder 3.08
As long as you have the stock cam, 600-800 is fine. Play around with it a little and find a speed that the car runs the best at.
mdtoren
08-16-2015 05:45 PM
