damp weather stalling
Car: 1986 Pontiac Trans Am
Engine: LG4 305
the restart is not too hard. cap, rotor plugs, and wires were all replaced less than 500 miles ago. but it will stall out when its damp out still. could this be related to the carburator?
Engine: LG4 305
at idle...
i'll start the car, it'll start fine. then i'll drive it to the first red light i see, stop.. the car's RPM's will slowly go from the idle rpms (700rpms), down to 0 and stall.
Engine: LS1/LQ4
Transmission: 4L60E/4L80E
If humidity is really the factor leading to your problems, the chances of it being the carb are pretty slim. Icing, maybe, but not likely.
Sounds more like a choke adjustment issue (pull-off, or opening rate).
darwinprice
17
10-11-2015 11:51 PM
HoosierinWA
10-07-2015 10:15 AM
3.8TransAM
10-01-2015 07:47 PM
