linkage for T.V. cable and cruise control for edlebrock 1407 carb?
Car: 1984 Trans Am
Engine: Vortec 355
Transmission: TH-700R4
Axle/Gears: GM Axles and GM 3.73
just wondering how everyone who is running these carbs is hooking up their T.V. cable and cruise control....because the linkage on there doesnt look like it will do all three lik the stock Q-jet's do, and also i was looking at Edelbrock's selection of linkages and none of them look to resemble to have the same sort of hookup that the stock q-jet's have.....anyone have a part number that has the hookup's for those two pieces?
Car: NCC-1701-D (docked in AZ)
Engine: impulse drive
Transmission: fusion reactors
Axle/Gears: Rescued from the Borg by my crew
Re: linkage for T.V. cable and cruise control for edlebrock 1407 carb?
Car: 1984 Trans Am
Engine: Vortec 355
here is a pic of what my problem is....but as far as what you guys were addressing....right now i have my stock carb,cruise,and t.v. bracket bent to fit my vortec intake....but thanks to your guys suggestions i see that jegs does sell a bracket made for the vortec intakes so thanks for that
here is the jegs part if u wanna check it out
http://www.jegs.com/photos/3508032.jpg
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Be sure to double check your TV cable geometry after installation. Most of the brackets on the market are for the TH350 kickdown cable, not the 700R4 / 200-4R TV cable. They can still be made to work though.
Engine: 383 Carb
Transmission: 4L60
Sorry, didn't see your picture there. Yes, those are the holes to use. The TV cable hole isn't really in an ideal spot, geometrically speaking. A couple of companies make little bolt-on adapters that put it back a better spot. It'll work as it is though but your part-throttle shift timing might not be quite right.
Car: 1984 Trans Am
Engine: Vortec 355
yea i was wondering about that too...but i figured that if i used that bracket from jegs, i could adjust it to the right height because it looks like the height is adjustable......
but as for the hookup for the CRUISE control?
any ideas? or suggestions
Engine: 383 Carb
Transmission: 4L60
You'd probably have to use a longer stud in the top hole that could mount the throttle cable and cruise cables. How is the stock cruise cable attached? Can you post a pic?
Car: 1984 Trans Am
Engine: Vortec 355
its not the best pic....wish i was near my car cuz i would go out and take a quick pic but this is the best i have.....
it looks like to make it all work i will have to make it so the top linkage spot (the BIG one) on the edelbrock to be the throttle hookup and the have the one i was going to do for the throttle as the curise control...and then for the t.v. still the bottom one.....
eightsixseven
08-14-2015 03:09 PM
Street Lethal
08-13-2015 08:28 PM
Street Lethal
08-12-2015 11:33 AM
