i'm new in third gen forum
Car: 87 trans am
Engine: 357 ci chevy engine
Transmission: th350
i'm new in thirdgen forum
hi
i am javier serrano from ponce puerto rico and i have a 87 trans am with a chevy 350ci and a th350 and stock rear end (2.73
possi
my question is how much power can i get with my car set up and what time a can get in the 1/4 mile?
my set up right now
gm 357ci block (350ci 0.040 over bore)
gm th350 transmicion
gm 350ci crankshaft
barry grant demon 750cfm
edelbrock torker 2 2500-6500rpm ported to match the heads
gm's #128 aluminum 58cc fully ported heads
1.5 rocket roller (like crane roller rockets)
edelblock valvule covers
msd pro billet distributor
federal mongul hypereutectics pistons
lt-1 stock rods
comp cams camshaft duration int230 exh236 lift 487int 490exh 110lobe
comp cams lifters
comp cams valve spings
felpro gaskets
trans. oil cooler
merlin high v. oil pump
hasting piston rings .040
aluminum crank pulley
gear drive
headmans long headers
3" catback
btw
i saw this forums about a year now
this is my first post
sorry my english is very very very bad but i try
![Frown](https://www.thirdgen.org/forums/images/smilies/frown.gif)
possi
my set up right now
gm 350ci crankshaft
lt-1 stock rods
comp cams lifters
felpro gaskets
trans. oil cooler
gear drive
3" catback
btw
![Roll Eyes (Sarcastic)](https://www.thirdgen.org/forums/images/smilies/rolleyes.gif)
![Big Grin](https://www.thirdgen.org/forums/images/smilies/biggrin.gif)
![](https://www.thirdgen.org/forums/images/ranks/tgo10.gif)
Engine: LS1/LQ4
Transmission: 4L60E/4L80E
Welcome aboard.
I've seen worse English from "educated" Americans.
That's a pretty healthy package. Probably well over 350 horsepower. With sufficient stall from the torque converter, 1/4 mile times in the low 13's, or high 12's with better gears and traction.
Car: 87 trans am
Transmission: th350
Originally posted by five7kid
Welcome aboard.
Welcome aboard.
Car: 87 trans am
Transmission: th350
Welcome aboard.
Welcome aboard.
Engine: LS1/LQ4
You'll probably need to stall in the 3000 RPM range. You'd know better if you have a dyno sheet, but without that you have to judge how the engine acts in the car.
You'll know you don't have enough stall if the engine acts a little sluggish off the line until RPMs build up and then it takes off. Mine needed 3000 RPMs even though all of the "powerband" information indicated it should have been less. Relatively small engine is the reason, in my case.
Car: 87 trans am
Transmission: th350
Originally posted by megaracerx
right obove the "reply" button, there a "edit post" button.
that way dont have to reply just to fix a typo
![Smilie](https://www.thirdgen.org/forums/images/smilies/smile.gif)
i have a internet conection probrems went i reply and because of that i replay twice the massege sorry
![doh](https://www.thirdgen.org/forums/images/smilies/doh.gif)
1 Post
Car: 83 Z28
Engine: vortec 305 for now
Transmission: 5 speed
Would he be better off changing the rearend gears, then running the car and at that point making a decision on the converter?
http://www.turboaction.com/frame.html
maybe you can contact these guys, they'r ein Jacksonville, Fl.
Car: 87 trans am
Transmission: th350
i have update my poject
here the information
gm th350 transmicion with hughers 2500 stall converter
gm 350ci crankshaft (0.010 over bore)
holley 750cfm with 2inch spacer
hoolley red electric fuel pump
edelbrock torker 2 2500-6500rpm ported to match the heads (single plate)
1.5 rocket roller (summit brand i think)
msd 6a
msd blaster 2 coil
accel 8mm spark plugs cable
accel u-grove headers spark plugs
lt-1 stock rods
comp cams lifters
comp cams push rods
felpro gaskets
trans. oil cooler
cat aluminum water pump
proform gear drive
3" catback
2.73 stock real end
any advice
msd 6a
msd blaster 2 coil
lt-1 stock rods
comp cams lifters
comp cams push rods
felpro gaskets
trans. oil cooler
proform gear drive
3" catback
2.73 stock real end
any advice
