Edelbrock 1411 Carb Problem
Old 12-27-2004 | 10:48 AM
POS Camaro's Avatar
Car: 1986 Camaro Z28
Axle/Gears: 3.73 Posi
I was driving the Camaro over Bromley Mountain in VT yesterday afternoon in a snow squall. On the other side of the mountain in Manchester the throttle felt like it was sticking slightly above idle. I put the car in neutral and gun it to free up the carb and it worked, for about 3 miles. It stuck again and I did the same thing. The carb appears to have the secondaries stuck partially open and now it wants to run at WOT the entire time.
Any help at trying to repair this will be appreciated.
Old 12-28-2004 | 02:28 AM
89Warbird's Avatar
Car: 1989 GTA Nighthawk
Engine: 389 CID TPI
Transmission: TCI 700R4
Axle/Gears: 9 bolt 3.23
Well, I'd like to help but I don't know what a 1411 is, is that a Q-Jet or a Carter?
Old 12-28-2004 | 01:17 PM
POS Camaro's Avatar
Its an Edelbrock Carb. 1411 is the model number, this is a 750 CFM carb.
I took apart the carb and cleaned some sediment from the fuel bowls. Put it back together and it is running fine now.
I don't know if it was dirty or frozen.
theshackle
09-17-2020 09:26 AM
Infested
05-23-2018 12:56 AM
beastin91rs
10-09-2015 08:38 AM
BlackphantomZ28
08-22-2015 02:00 PM
86IROC112
08-17-2015 03:00 PM
Quick Reply: Edelbrock 1411 Carb Problem
