Need new carb
Car: 1984 Camaro Z28, 1987 Z28 (R.I.P.)
Engine: 305 H.O.
Transmission: 5 Speed
Need new carb
Hey, I got a Rochester 450 carb right now for my 305 H.O. and I want to buy either an Eldelbrock (Since i drive the car a lot and don't only race) or Holley.. I'm not really a pro when it comes to carbs, What would you suggest me for a Holley carb? And what does Ford A/T and the Model 4160 means?? Is that only for roadsters? I would like a 600 or 650 CFM. Thanks
Car: 1966 impala , 1998 sebring vert,1978 buick regal turbo, 1991 chevy silverado 3/4ton 4x4 lifted
Engine: 283, 2.5,3.8 turbo 350
Transmission: powerglide,auto overdrive, th350,4L80
Re: Need new carb
http://www.edelbrock.com/automotive/carb_square.html
itll work great for what you want and its very easy to tune and work on ..
alot of guys here will tell you to run a holley ..but for what its worth ive had 4 different edelbrock carbs on 4 different cars and never had a problem out of them ..
Engine: LS1/LQ4
Transmission: 4L60E/4L80E
Some things aren't adding up.
What's a "Rochester 450 carb"?
In 1987, GM didn't make a 305 HO for 3rd gens. Has something been swapped in?
With a manual transmission, you're a little better off with a double pumper style carb. The only choices you have there are Holley and Demon.
Don't worry about "Ford A/T". It won't affect you.
Model 4160 is a Holley designation for their vacuum secondary, with secondary metering plate rather than replaceable jets carbs. It's their most common seller. However, if you follow my advice above, you'll be getting a 4150 model (if you go with Holley).
Or a holley 6210 spreadbore dp 650 cfm Qjet replacement carburetor.Works great on my Z,and I can keep my 305 HO air cleaner.It takes a divorced choke but that is simple stuff.........Good luck with whatever you purchase.
Engine: 305 H.O.
I might just buy Eldelbrock.. But I would like something like the carb I have right now.. Gets more prime has the RPM keeps going up.. The opposite of Edelbrock's.
I haven't had the car for long, I think the engine has been swapped but I'm not 100% sure. I looked for the #'s on the carb on the internet and it said something about a Rochester 450 for 73 Corvette's..
Would this Holley be good..
650 CFM Four Barrel
Model 4175 spread bore
Q-Jet/Thermo-Quad replacement ?
And do I really need to change distributor??
I have an Accel one right now..
Thanks for the help
650 CFM Four Barrel
Thanks for the help
I you have a vacuum advance style hei and a 73 non cc qjet then you dont need to change your distributor. Youve already been converted from computer control. Or you never had it since its a canadian car.
Car: 1986 z28 camaro
Engine: 305 4bbl
Transmission: t-5
I would go with an edlebrock 600, my 650 is just a hair too big. other than that, I love it. just keep in mind you will need an adapter or a new manifold to get a squarebore carb to fit.
Engine: LS1/LQ4
With a 305 or the typical stock 350, you don't need any more carb than that.
RedLeader289
05-28-2019 01:47 PM
efiguy
09-27-2015 01:30 PM
