carb decode
Car: 02 z28, 03 wrangler sport
Engine: ls1, 4.0L
Transmission: t56, 4speed auto
carb decode
i can decode some numbers on the carb and it will tell me what cfm it is right? if so can you tell me where i can decode the numbers.
Car: 1966 impala , 1998 sebring vert,1978 buick regal turbo, 1991 chevy silverado 3/4ton 4x4 lifted
Engine: 283, 2.5,3.8 turbo 350
Transmission: powerglide,auto overdrive, th350,4L80
Originally posted by kamaroirock
i forgot to mention its a edelbrock
looking at the front of the carb where it bolts to the intake on the left side where the bolt goes thru you will see some numbers stamped on the front of this peice those should be what you are looking for
here ya go this is what it says it is
600 cfm Carburetors
Street Legal, Electric Choke
50-state street legal for all 1980 and earlier General Motors V8s (E.O. #D-215-10). Calibrated for maximum fuel economy. Includes timed vacuum ports, EGR and fuel vapor outlet. Not for computer- controlled engines. Comes with the following jets, rods and springs: Metering Jets – Primary .098, Secondary .095; Metering Rods – .073 x .047; Step-Up Spring – orange (5" Hg). Includes carb studs and hardware.
* 600 cfm, square-flange, electric choke, EGR ....#1400
got it here
http://www.edelbrock.com/automotive/carb_square.html
600 cfm Carburetors
got it here
no problem
![](https://www.thirdgen.org/forums/images/ranks/tgo10.gif)
Engine: LS1/LQ4
Transmission: 4L60E/4L80E
![Wink](https://www.thirdgen.org/forums/images/smilies/wink.gif)
Originally posted by five7kid
Vital little tidbit of information...
RedLeader289
05-28-2019 01:47 PM
efiguy
09-27-2015 01:30 PM
