witch carb?
Old 10-30-2004 | 12:13 PM
sprayedcam86's Avatar
Car: 86 camaro z28
Engine: wild 355 chevy sprayed with nos
witch carb?
currently im running a holley 650 double pumper. the accelerator pump is going out so im going to get a new carb. does anyone have any recomendations on witch one to get. i like the holley but it stalls bad on acceleration. are holleys bad about this? my engine is a pretty wild 355 running a 150 shot of nos. ive been told to get a demon. i had an edelbrock but it seemed like i didnt get the same power at high rpms like i did with the holley. any suggestions would be helpful and some part numbers if anyone has them.
Old 10-30-2004 | 12:45 PM
chevydude350ho's Avatar
Car: 90 Iroc-Z
Engine: carb'd 350
Transmission: built 700r4/3000 stall
why not fix the holly? it wouldn't cost much at all to fix the accelerator pump and that should fix your bog.
Old 10-30-2004 | 04:07 PM
Car: 86 camaro z28
i would but ive had nothing but trouble with this carb. its had two rebuilds already. i think its just a bad one. so should i bother with another holley or go with a different brand.
Old 10-30-2004 | 06:06 PM
65panhed's Avatar
Car: 1984 Z28
Engine: L69 305 HO
Transmission: 5 speed manual
Axle/Gears: Auburn pro yukon 3.73 gears and axl
If you understand carb basics you can tune this carb.What is the list #? Holley tech is great,give them a call they will be glad to help.Or try to contact RBL69 or 57 kid they have as much info as anyone on the boards.Also do search on your carb problem or your list # and see what that turns up............
Old 10-30-2004 | 06:24 PM
IHI's Avatar
IHI
Car: 86 firebird with 98 firebird interi
Engine: pump gas 427sbc Dart Lil M 13.5:1
Transmission: Oldani TH400 w/ BTE 9" convertor
Axle/Gears: 31 spline Moser/full spool/4.11Rich
If it's a wild 355 with a shot of juice, you should really be using a 750DP at a minimum like the 750HP holley. Very very good carb outta the box and with some minor tuning you'll be going faster than you ever did with that 650DP.
Old 11-04-2004 | 01:37 PM
Car: 86 camaro z28
takeing your advice im looking at the 4150 hp series holleys in the 750cfm model. should i get the mechanical or vacume sec. now my 650 is machanical. the part number of the ones im looking at are hly-0-80528-1 for mech and hly-0-80529-1 for vac. these are summit numbers.
thanks
stephen
Old 11-04-2004 | 01:46 PM
IHI's Avatar
IHI
If you want 100% kick in the pants power- mechanical secondaries hands down!!! The 750VS will work, but will not be as performance minded ouotta the box or on top as the DP will be.
The HP series you have picked out for the DP is a perfect choice, kinda spendy when compared to other lesser models, but alot of power to be had from these HP units. The truck is running the 750HP in my sig, I personally run the 950HP. I have'nt had a chance to throw the 750HP on mine to see if any gains are to be had, but I'm making more hp than the trucks motor so I dont think any would be had. The trucks motor dynoed at 555hp/505tq with the 750HP, but the VE% only hit 100% for a short bit and max CFM the motor pulled was only 630cfm, so the 750 is just right. They tried the smaller carb and it lost hp/tq, smae thing happened when they installed the 850 lost hp/tq.
Old 11-04-2004 | 02:12 PM
Car: 86 camaro z28
thanks alot for yor help
RedLeader289
05-28-2019 01:47 PM
mcfastestZ28
10-01-2015 11:23 AM
IROC ZELLER
09-29-2015 03:00 PM
efiguy
09-27-2015 01:30 PM
Quick Reply: witch carb?
