Different types of choke--
Car: 1986 Firebird
Engine: LG4 305
I know many people on these forums are in favor of keeping the computer controlled carburetors, but I've decided not to. But I have decided to stay with the quadrajet models so that I can keep the stock air cleaner assembly. After looking at parts, I've found that there are 3 types of chokes on quadrajets:
Divorced Style (1966-1978)
Hot Air Style (1975-1985)
Electric (1980-1989)
I can get any of these without the CC.
Can anybody tell me what the difference is?
I want a choke that turns itself off and on without any external linkage or computer. Thank you!
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
The choke on your stock carb isn't computer controlled. Get another electric choke carb and you can connect your existing choke wiring to it and it'll work fine.
A divorced choke has the coil mounted separately from the carb in a well inside the manifold where its heated by the exhaust crossover. You don't want one of those. A hot air choke has the coil mounted on the carb but uses a tube to draw exhaust-heated air from the same well to heat the coil.
There were also hot-water chokes that used coolant, and electrically-assisted chokes that used a combination of methods, but none of these were available on Quadrajets.
1978, air, automatic, carb, carburetor, carburetors, choke, chokes, connections, devices, differnt, hot, of, quadrajet, types
