what`s wrong with my holley??
Car: 1985 Z28
Engine: LG4 305 with a few modds
I have a 600 vac. sec. holley list 1850-2. I rebuilt it last summer and never ran it till today. It won`t idle under 1500 and I have to have idle mix screws out 4 turns and the idle screw almost all the way down just to keep it running, I can`t get the floats any lower and gas still runs out the sight hole. at around 3000 it smooths out but it`s still RICH as hell, just this HUGE cloud of black smoke behind my Zed.
Car: 1984 Trans Am WS6
Transmission: 700r4 Highly Modified
Did you happen to adjust the screw under the back passenger side that adjusts the secondary flaps when you did the rebuild? This will do it also.
Car: 2000 firehawk
Engine: ls1
Transmission: 6 speed
Axle/Gears: 3.42 auburn
when you rebuilt your carb and wiped out your fuel bowls you may have messed up your float settings, id check those if your still pouring gas out the feul level holes.
Car: 1966 impala , 1998 sebring vert,1978 buick regal turbo, 1991 chevy silverado 3/4ton 4x4 lifted
Engine: 283, 2.5,3.8 turbo 350
Transmission: powerglide,auto overdrive, th350,4L80
Sounds like its time to buy an edelbrock
RedLeader289
05-28-2019 01:47 PM
Royal_Z
09-30-2015 08:45 PM
