secondary float level problems
Car: 1988 camaro/1992 camaro
Transmission: 700 r-4
hi all,im having problems adjusting secondary float levels.primaries are fine,cant seem to get fuel to stop pouring in no matter what i do.i have taken bowl off and set it twice no luck the carb is a demon junior carb is brand new.i thought might be fuel pressure,but just under 5 psi,primary float level fine any help greatly appreciated thanx :hail:
Car: 88 formula WS6
Engine: 305 Lo3
Transmission: 700-R4
Over rich condition may be caused by, (considering the fact that it's new) manual secondary's out of adj. (linkage) secondary's open too far. Bad power valve, timing too far retarded. Float level set too high (adj.) When all else fails, call the manufacturer and tell them your problem! They should have a help line # to work with you!
its a vacuum secondary carb just having problem setting the secondary float level only
Car: 88 formula WS6
Engine: 305 Lo3
Doesn't it have an external float adj. screw on the top of the bowl
and a sight glass or screw on the side of the bowl? Hard to believe the allmighty deamon didn't come with those options!
yes it has external adjust float bowl just doesnt seem to do anything even with slight adjustments.it just keeps filling with gas till it starts leaking out.thanx for the responses guys :hail:
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
You cleaned the needle, but did you check the seat? What kind of fuel pump are you running?
im using the tbi intank pump brand new with the mallory return style regulator primary bowl is set.seemed to work fine when i took float bowl off to clean things and set float,and to make sure fuel is getting to secondaries .at first i didnt have gas coming up in secondaries now i get to much.didnt get anything with the top float adjustments.once in awhile fuel pressure fluctuates all below 6 psi though.needle seat?just looks like thin sheet of metal with little bump on it .sorry new to carbs but learning.
Car: 88 formula WS6
Engine: 305 Lo3
I can give you things to look for!! Although I would suggest cont. the Mfg. for waranty purposes first, here's the list.
1. Make sure your turning the adj. screw the right way. (clockwise to lower the fuel level, counter clock to raise).
2. Being your adj. it from the inside bend float tang towards needle valve to lower fuel level.
3. Remove the float and shake to see if there is fuel in it (bad float)
4. Check power valve # for correct application (power valves are designed to open at different vac. levels.
5. Check power valve gasket for proper seat. (If you backfired after installation could have blown power valve but I think deamon would have anti backfire valve to protect it).
6. Check bowl to metering plate and metering plate to carb. body gaskets for fit and proper installation.
7. Check carb. to intake gasket for proper application (you might need a four hole spacer plate between the carb and intake if your running an open plenium).
8. Check the bowl vent to make sure it isn't pluged up with something.
9. Check throttle plates and make sure they are closed all the way on the secondary's.
10. Equalize the fuel feed lines to your bowls (fuel line, regulator, T or Y fitting, and equal length lines to each bowl) the fancy chrome jobs deliver a minut amount more pressure to the secondary's being the primary bowl is farther away from the secondary.
Man, that's about all I can think of at the moment! Hope this helps you some. I've gone through a half a pack of smokes just writing this! Any more and I'm going to choke! Good luck!
Wait a minute, (puff puff) this isn't necesesarly in order so do the obvios things that don't require dissasembly first. OK!
not able to look at the problem today.thank you everybody for your responses.
thanx everybody was needle valve got new one.sqzbox i owe u half a pack of cigs lol ill take the other half thanx for responses all
Car: 88 formula WS6
Engine: 305 Lo3
Good deal (royal flush!) How bout' posting the results on how it runs after you get it out on the street? We love results!
Hotrodboba400
12-10-2019 07:07 PM
86CamaroDan
09-29-2015 10:08 PM
