Proform main body question
Car: 2002 Formula Firebird
Transmission: 4l60e
I have a 670 cfm street avenger carb. I'd like to add one of the bodies to it if possible. They have one for a 750cfm vac secondaries. I know the metering blocks and all would fit BUT i was wondering about the butterflys. I'm assuming that wouldnt work.
I thought maybe there was a way this would work because the body for a 650-750cfm DP are the same...
Car: 1984 Camaro Z28
Engine: Blueprint 383
Check out this page and see if you can find your carb number.Proform main body
Transmission: 4l60e
According to that it will not work. It says only the 750 VS....
I just dont see how the DP body could work on a 750cfm and a 650cfm...I know the butterflys are different...
I'm confused.
I'm confused.
Transmission: 4l60e
My baseplate is the same as a 600cfm holley I checked that out.
I will pull the street avenger off the shelf at work and see what number it shows.
Id like to be able to use one of the bodies...it would save me a few bucks.
Transmission: 4l60e
I know but would it work with mine?
The butterfly sizes have to be different don't they?
Only numbers I could find on my baseplate were 11466 and 11469... 11466 is on the top and 11469 was on the bottom.
Butterflys have 109 stamped on them.
I said baseplate - the butterflys should be stamped 172/173. The baseplate bores are suppose to be 1 11/16 inch. Like five7kid said, I think the VS have different sizes.
