Tuning my Holley
Car: Z28
Engine: 310
Tuning my Holley
Alright I got a race coming up and I need my carb tuned perfectly. It's Holley 650. When I'm driving the car it runs smoothly, until I romp on it, when it's floored it'll pull hard for a second then cut out and fall on its face. I'm pretty sure this means it's running lean but I'm not 100% sure.
Car: 1984 Trans Am WS6
Transmission: 700r4 Highly Modified
That pump should work fine for you. How long have you had the carb on the car? It may have a passage clogged somewhere.
Car: Z28
Engine: 310
well the car worked fine when I first bought it. Thats when it was stock. After the engine was rebuilt it's never really ran right.
Car: Z28
Engine: 310
Well I've been driving around it seems like it stumbles when the secondaries open. Maybe I need larger jets for the secondaries???
Car: '82 Z28
Check to see if the pump arm for the secondaries doesn't have any play. It might not be getting a squirt of fuel right when the secondaries open.
Car: Z28
Engine: 310
Just checked the pump arm, there is a little bit of play. I think a little bit would be normal but I dont know. What do you think I should do to tighten it up?
If there's play when the throttle is closed, it's wrong. It should move the pump instantly. When the throttle is wide open, you should be able to move the lever about .015" more before bottoming out the lever to the pump.
