Victor Jr under stock hood???
Car: 96 SS, 88 IROC
Engine: Lt1, TPI
Transmission: m6,a4
Axle/Gears: 3.90. 3.73
Hey guys, would a victor jr fit under my stock powerbudgle hood???? need to know picking up the intake soon, need to know wheather or not ill be driving without a hood
Car: '82 Z28
It should fit, mine does just bearly and I'm betting I have less hood clearance than you. Also running a drop base air cleaner.
Car: 2013 Challenger RT
Engine: 5.7
Transmission: 6 spd
Axle/Gears: 3:92
Does the stock (not powerbulge) firebird hood have an inch less hood clearence than the camero?
I too am concerned with hood clearence. But I am now confident the stealth intake I have will fit after seeing the victor under the hood of the camero.
Car: 96 SS, 88 IROC
Engine: Lt1, TPI
Transmission: m6,a4
huh ok ill give it a shot.... kinding making my 305 wild till i can afford a 350. got the victor jr intake ported polished aluminum zz4 heads lt4 hotcam 600vs holley.. should be a nice setup, ill let u guys know my progress
I havent tried the setup w/ a vic jr, but I had a performer rpm which is actually slightly taller than the vic jr under my stock T/A hood. I had a 3" drop base, and it actually touched the insulation with the hood closed, but it fit. W/ the vic jr being just slightly shorter you should be able to get away w/ it as long as you have a drop base.
Ben
Ben
Car: 96 SS, 88 IROC
Engine: Lt1, TPI
Transmission: m6,a4
oh sweet then i know it will work. i had the rpm under my hood worked fine... thanx for the help guys
Street Lethal
04-30-2019 12:14 PM
Black89TA
Exterior Parts for Sale
07-23-2016 10:42 AM
