Q-Junk Secondary Metering Rods
Car: 2013 Challenger RT
Engine: 5.7
Transmission: 6 spd
Axle/Gears: 3:92
Q-Jet Secondary Metering Rods
I have posted several times on this topic. So, bear with me.
I am giving a Q-Jet to a friend for his stock non-computer 350 with cast iron exhaust manifolds. The carb has the "CV" (close to CK)secondary metering rods on a "B" hanger. Will this be too much for the 350 with iron manifolds? Or should we start with a leaner hanger?
Engine: LS1/LQ4
Transmission: 4L60E/4L80E
You start by insulting the carb in the topic line, and then want us to give you advice? What's wrong with this picture?
Since I don't share your opinion of the carb, I'll respond anyway.
Both should be fine.
Engine: 5.7
Transmission: 6 spd
Axle/Gears: 3:92
Thanx will try it.
PS. I also like the Q-Jet. It is a great stock to mild performance carb. We have been calling it a Q-junk since the 80's. Don't know where we picked it up.
LT1Formula
10-08-2015 08:34 PM
skinny z
10-05-2015 06:23 PM
