whats
1 Post
Car: 83 Z28
Engine: 400sb
well the reason i ask is that my car runs so rich that when i stopm on the gas its nothing but black smoke out the exhuast with the edelbrock that i have on there now
1 Post
Car: 86\92 Mutant
Engine: 355CI 430HP
Transmission: T-5 with mods
Axle/Gears: 7.625", Eaton Posi, 3.73
Is the Edelbrock new? What Model is it? Have you tried any basic tuning such as Primary rod changes or accelerator pump tuning?
No reason at all why you shouldn't be able to tune that Edelbrock properly.
1 Post
Car: 86\92 Mutant
Engine: 355CI 430HP
Originally posted by 305sbc
I wouldn't run anything smaller than an 800cfm on a 400,
but mech or vacuum will work fine with automatic trans.
Once you go past 750 CFM, Holley changes the main body design and goes to a larger Venturi on the Secondary side on an 800CFM. This drastically reduces Booster signal.
750's use 1-3\8" Venturi's on the Primary and Secondary sides. They also have 1-11\16" throttle bores.
800's use the same size throttle bores but use a 1-7\16" Secondary Venturi. This drops booster signal dramatically, which can be detrimental to Performance......particularily on a mild, street driven motor.
Once you get to an 850 the changes are even more dramatic. Annular Booster are highly recommended on anything 850CFM or larger. Annular Boosters give a much stronger Booster signal than Straight or Dog-Leg Boosters.
With a mild cam, street driven 400, such as Z28Guy's, a 750 CFM DP\VS is more than adequate. With the simple addition of a "K&N Stub Stack" you can pick up around 25 CFM. Do a little massaging to the throttle shafts and you can pick up another 20 CFM. All with a more responsive carb.
If you're twisting the 400 over 6,500RPM..then an 800 may be necessary. Anything below that then I'd recommend a 750....IMHO.
Check things like if the secondaries are opening up at WOT,
Are the tiny air-bleed holes dirty or plugged with corrosion?
Is the float level correct? Do you have a leaky float?
Do the needle & seats seal correctly?
Bad needle & seats causing flooding, or dirty air bleeds are common causes for the Edelbrock/Carter carbs to cause black smoke.
All this is assuming #1 The smoke you're seeing is due to too much fuel ( not oil ), and #2 you do not have an ignition or timing problem.
The Edelbrock should be very easy to correct/fix once you figure out what is wrong. I didn't realize that you were having this problem.
1 Post
Car: 83 Z28
Engine: 400sb
the carb is a 660 cfm with manual secondaries (i forget the exact model #)
yes the secondaries are opening up on WOT yes everything is clean the smoke im seeing is fuel due the fact that i smell like gas after i drive the car ill have to get the tuning kit and try some different metering rods for the secondaries cause it onlt does it at WOt
metering rods are only for the primaries.
Some ignition problems only show up under load like WOT.
If the carb and ignition are operating normally, then the only way you would be running rich at WOT is because of too much signal at the boosters at WOT. About the only way that happens is when the carb is too small.
