vacuum advance hits intake
1 Post
Car: 91 RS Convertible
Engine: 355
Axle/Gears: 2.73 peg leg
Hi. I'm finally back to work on my project, but I am unable to set the timing where it needs to be because the vacuum advance module on the distributor hits the intake manifold and I cannot advance it enough to make it run properly. Do I have to go to a mechanical advance dist or can I make this one work somehow. I'm running the summit distributor and the Holley Dominator Dual plane. Thanks
TWON_3rdGEN (04-26-2020)
Engine: LS1/LQ4
Transmission: 4L60E/4L80E
You want to move the shaft clockwise one tooth so the housing moves clockwise with it, and you can then rotate the housing counterclockwise to advance the timing w/o hitting the intake. The oil pump shaft probably won't line up when you do the one-tooth move thing, don't worry about that just set the distributor in, let it rest there, and bump the engine - the distributor will drop down.
The Summit distributor is a mechanical advance distributor. It has a vacuum advance as well (as do most non-CC distributors).
86IROC112
08-17-2015 02:00 PM
mdtoren
08-16-2015 05:45 PM
