Intake ?
Engine: LS1/LQ4
Transmission: 4L60E/4L80E
From http://www.edelbrock.com/automotive/index.html
"Designed for street 262-400 c.i.d. Chevy V8s that have heads with canted center bolt holes. #2104 is stock replacement/street legal part for 302, 327, 350 V8s with OEM 4-bbl. carb.; except stock equipped EGR. #3706 is stock replacement/street legal part for 305, 350 V8s with OEM 4-bbl. carb.; 1987. Both accept late-model waterneck, air-conditioning, alternator, H.E.I. and have rear water crossovers. #2104 accepts exhaust-heated chokes. For 1987-95 stock aluminum heads use #2101. Will not fit Chevrolet Bowtie or LT1 heads."
Both accept either spreadbore or squarebore carbs.
Is there any other company that makes a manifold similar to the performer that bolts up to 87 & later heads and does not need an adapter for my square bore edelbrock carb.
Thanks for all the help guys keep it coming
jerflash
09-24-2015 03:11 PM
toronto formula
09-10-2015 07:31 AM
e3pres
09-09-2015 01:51 PM
