jetting an edelbrock 600cfm carb.
Car: 1982 Camaro Z28
Engine: electric
Transmission: powerglide
Axle/Gears: 10 bolt
i bought the edelbrock 600cfm carb. (part # 1406) and i have know clue how to adjust it, so i just threw it on the car and it runs but really rich. how can i lean it out?
swap the primary jetting and secondary jetting.
this will be a step in the right direction.
By swaping the .098 primary jets for the .095" stock secondary jets you will lean down the low speed and cruise "jetting by 12% and lean down the primary full power jetting by 4%
Secondary jetting will be richened 4%
for more tuning you'll need to buy a tuning kit
consisting of jets, metering rods, power step springs etc.
you can read all about tuning edelbrock carbs here
http://www.telusplanet.net/public/gi...delbrock_1.htm
read it, know it, there will be a test.
edelbrock carb do not like too much fuel pressure.
How much fuel pressure do you have at idle.
Should be 6 psi.
While you have the top off the carb swapping jets you can check the float height setting.
Should be 6 psi.
Engine: electric
Axle/Gears: 10 bolt
i can just smell the unburned fuel, i have alot of dirtbikes and i have jetted them i just didn't know really where to start with this. Thanks for the website F-BIRD'88 it helped alot. I haven't checked the fuel pressure yet so thats were i think i will start. Thanks again
RedLeader289
05-28-2019 01:47 PM
efiguy
09-27-2015 01:30 PM
Night rider327
09-25-2015 04:47 AM
