LT1 with Carb?
LT1 with Carb?
Has anyone here put a carb on an LT1 engine in a 3rd gen firebird? How might it affect horsepower, fuel economy, and can the LT1 intake be used? How tough would it be to switch the distributor?
![](https://www.thirdgen.org/forums/images/ranks/tgo10.gif)
You need a special intake manifold unless you're accustomed to modifying and fabricating your own parts. GMPP makes an intake designed to bolt on top of an LT-1 and has the hole in the back for a standard rear-mounted distributor.
What you do with the old Optispark I have no idea. Probably just leave it bolted on but don't hook it up to anything.
Fuel ecomonmy will probably suffer somewhat, depnding on how sharp a carb tuner you are. Torque is probably a little better than the LT-1 intake due to the longer dual-plane intake runners, but HP is probably about the same.
jerflash
09-24-2015 03:11 PM
mygta87
09-14-2015 10:36 PM
