who drives a computerless carbed daily driver?
Car: 1991 RS
Engine: 305 TBI
I want to know if anyone has gone all motor with no computer. Just all engine, tranny and battery. Real simple. Is this possible for a daily driver?
You see, I have a 305TBI now, but I want to gut it out of my Camaro, rip out all the wiring, smog equipment and go with a carbed computerless setup? Is this possible, or more importantly is it sensible?
Also I need not any input on SMOG Law. Its not an issue for me. Thank you, Eric
![](https://www.thirdgen.org/forums/images/ranks/tgo10.gif)
Well, 20 years ago we all drove cars like that. A carb can be very friendly on a daily driver if properly tuned. It'll never have the all-weather perfect performance of a well-functioning EFI setup, but you can make a carb run pretty darned good. You don't want to go crazy with the cam- EFI can compensate for a big cam much better than a carb can (especially idling and at light throttle/low RPMs) but the short answer is still basically Yes.
Car: 85 iroc z
Engine: LG4 :(
Transmission: 5 speed
I don't use mine as a daily driver anymore, but I used to. It was perfectly fine as a daily driver.
It has an Edelbrock 600cfm carb, open element, shorty headers, edelbrock performer intake on an LG4, oh yes and a 5 speed tranny. No smog stuff, No A/C. All thats on the motor is two belts, the alternator and the power steering.
As was said earlier as long as its tuned correctly you'll have no problems.
Oh, how did we ever manage before the fabled computer?
Gees let me count the ways.
![Embarrassment](https://www.thirdgen.org/forums/images/smilies/redface.gif)
Car: '87 Camaro LT
Engine: 355 L98
i put on a used holley 750 and it ran pretty good. my only complaint was an off-idle bog, not bad for not rebuilding and not tuning the carb. it's a good idea to do some tuning if it's needed but chances are you can find a carb that'll be very close to 'just right' out of the box
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
i USED to.....
http://josh.swoca.net/board/mrdude/the%20engine.jpg
http://josh.swoca.net/board/mrdude/the%20engine2.jpg
http://josh.swoca.net/board/mrdude/e...aircleaner.jpg
car was already computerless when i got it.
Car: 1983 Trans Am
Engine: N/A
Transmission: N/A
What doe it take to properly tune a carb?
I hear people talk about how when they take the computer out they have to tune-up the car almost weekly, and with a computer you only have to tune it up about as often as you change the oil..
In my mind, it made no sense.
Car: '94 Corvette
I had a Carter 625 & Comp280H in my old Camaro. The only thing I did was change the oil every 3K for over SIX years that I drove it as a daily driver.
Now how did that go in the winter? gas-gas-start-part gas-choke to half-wait 10minutes![Smilie](https://www.thirdgen.org/forums/images/smilies/smile.gif)
Ron
Ron
Car: 1987 Chevrolet Camaro Z28 IROCZ
Engine: L98 350, mini ramed and camed
Transmission: T56 6 speed manual
Axle/Gears: 10 bolt 3:73 limited slip
I had a 350 with a 600 cfm carb on it, no a/c and no smog. It ran sweet for a daily driver!
![Big Grin](https://www.thirdgen.org/forums/images/smilies/biggrin.gif)
Car: 91 Camaro Vert
the only diffs between my carbed 400 and a FI one would be:
1 when you start it. you pressed the gas one time then turned the key. once you get used to it, it becomes 2nd nature. and it will start QUICKER then a 3rdgen FI car....
2 when its cold, the idle from the elec choke is higher, so you SHOULD wait a min with it at high idle.... but with my eldlbrock, if i flicked the gas, i can make it idle down quickly.... athough its a bit of a rough idle until it fully warms up..
personally, i think most of the bad rap carbs get now days is from people that didnt grow up with carbed cars... they claim they're hard to start ( they dont know what a choke is) they say it runs like **** ( they just bolted it on there, and it seems to run fine)
cars have been running fine on carbs for over 100 years.....they work just fine as daily drivers
![Stick Out Tongue](https://www.thirdgen.org/forums/images/smilies/tongue.gif)
Car: No more birdy
The only reason people "tune up" thier carb cars is because theres always room for improvment. It's not like an injected setup where most people just look at the TB if thier not happy scratch thier head and mummer humph. With a carb you can always adjust somthing and parts cost practicly pennies.
Car: '87 Camaro LT
Engine: 355 L98
i'm getting ready to rebuild and tune my holley 4160 and by the time i figure out which jets, springs, cams, etc. i need it looks like it'll cost me an arm and a leg
Car: 91Z, 91RS, '84 Jimmy
Engine: L98, 355, L98
Transmission: 700R, T56, 700R4
That's why I like my Edelbrock 750. A $40 rod and jet kit is all the tuning I'll ever need.
I have that carb on a 355 with HEI ignition and a T-56 and use it as a daily driver. It cranks and runs just as well as it ever did with TBI.
Car: 1988 GTA
Engine: 5.0 TPI
Axle/Gears: 9 Bolt, 3.45
Ok, its not computerless, but come on, the carb computer does next to nothing :P My car still has the CC carb, and is still runing the 305 LG4 ECM. Its by no means an ideal setup, but it works. I drive it every day to work, and it gets me there fine, sometimes with the occasional race on the way :P. I have done a few things to it to make it a better daily driver though. I changed to the 88-92 serpentine belt setup, its much better than the crappy v-belts. The engine felt much smoother after installing it. I also changed to an aluminum radiator, and electric fan. The old belt driven fan and copper/brass radiator just werent enough for sitting in dallas traffic. I've also added a front airdam from an 89 RS. It hangs down a little lower than the stock one (my stock one was busted up), and it doesnt come out all the way to the fenders. I have no cooling problems at high speed now, not even at 100+ mph
All of these parts came from the junkyard too, at less than $200 for everything. I have tuned the carb, just about exactly where it needs to be. I never get any black smoke from the exhaust or anything. I'm not exactly sure how its possible, but I get about 20 mpg on the highway, and not much less in the city. I drove from here to San Marcos, TX once, on exactly a full tank of gas. Its around 300 miles to there. Divide that by 15.5 gallons, an thats almost 20 mpg...
Car: 1999 Pontiac T/A Firehawk
Engine: ***'s Engine
Yup, my daily is my '84 Olds 3.8L V6. It started life as a CCC Dualjet, switched to a CCC Qjet, and now it's running as a non CC Qjet.
It's averaging about 18mpg with the A/C on. I'm definitely losing some mileage from the lack of the lockup.
Runs good, though it feels like it could use a slight step up in jet size.
Car: 1984 CAMARO Z28 with T-TOPS
Engine: 5.7
Transmission: 700 R4
Carb
I like "What did we ever do before computers????"
I love my 84 Z with carb.
We put a Holley in a few wks ago w/the Holley breather.
It's my daily driver.
1 Post
Car: 89 RS
Transmission: TH350
OK, heres the run down...
Stock - 86 IROC with a TPI 305.
Now - 86 IROC with a carbed 350.
Alright, the motor was swapped out before I got it. So when I purchased the car it had a non-CC dist. trying to work with a CC-Q-Jet. Needless to say gas mileage was out the window, not to mention performance. So I swapped on an Intake and Holley 600 Carb. with Vac. Sec., not expecting much, but the difference was night and day. Better performance and way better gas mileage. I can see 24 mpg crusing 70mph on the freeway for a long trip. City cruising Mpg falls off, but not that much. But thats to be expected with occassional romps on the pedal.
Overall, a carb can be made to be a great daily driver with minimal keep up, esp. now a days. A little tune every now and again, but alot less expensive than EFI. I can usually tune mine with just a Vac. gage and looking at the plugs, try that with TPI or TBI
Also, the car is a true daily driver, maybe 30 miles a day, but I will snap a pic of my dusty carbed engine bay if you want.
Car: 86 iroc
Engine: 350 carbed
Transmission: t5
Re: my 83 z
Originally posted by Z28guy83
has no computer with my carbed sbc 400 and i drive it daily here is a picture
Car: Bright Red 91 GTA
Engine: CARBED LT4
Transmission: MK6
Re: Re: Re: my 83 z
lol i just rolled it out of the garage
hope you didnt roll iit out...may want to stick that tpi back on lol....
my car will be a daily driver...
350 LT1 motor
LT4 heads
and a holly 750 vac secondary
only thing ill miss is the gas mileage..
used to get 26-28 on the freeway with my LB9 t-5
Car: 05' GTO
Engine: 6.0L
Transmission: A4
no computer here, and im gettin about 165 miles to a tank of 94 but alot of the gas wasted is just lettin it get a little warm up in the morning mostly 5mins and im off for the day(work) and after the car sits for about 9hours i let it warm up for 5 more mins and im good for the rest of the day.
and my cars been computerless for id say about 10yrs+ now.
Car: '82 Z28
Daily driver
Over the weekend I did a 170 mile round trip to the drag strip with 4 passes. Probably could have made it on one tank but got nervous lol still above the E line by the width of the pointer when I filled up. Had about 20 miles to go.
![](http://www.norcalbowtie.org/images/demonon305.jpg)
Car: 1986 Sport Coupé
Engine: 305-4v
Transmission: 700R4 and TransGo2
You should be able to get at least 250 miles to a tank in town.
Car: 05' GTO
Engine: 6.0L
Transmission: A4
also half the time of my gas wasted it just sittin ideling/warming up, i drive maybe like 20mins aday and thats to work and back. and then carshows on wed. nights and thats it. one tank of gas lasts me abut 21/2-3 weeks
Car: 1986 Pontiac Firebird S/E
Engine: LG4 TPI Conversion
Axle/Gears: 3.42 SLP Posi 10 Bolt
I have a Q-Jet from a 1979 350 Chevy Van in my daily driver. It's too much carb for the crappy 86 305 V8 stock cam, and it always seems to run slightly rich. It runs rough for about 5 minutes when it's cold, but once warmed up I'm getting about 17 MPG on 87 Octane.
If I had it to do over, I'd have put a bigger cam in at the same time, like a stock replacement for the 1979 Chev. Van.
I'm building a 350 .020 over with a Comp XE cam and Edelbrock 600 CFM carb, I hope to have it in by August.
Engine: 305-4v
I know GM has made different size QJets but almost every one of them since the 70s have been 750 cfm models, even if it takes a couple adjustments to get that cfm out of them.
Car: 89 Camaro RS
Engine: sbc 400
Transmission: th350
i'm about 3/4 of the way done with a tbi to carb swap on my daily driver. all that i really got left is to hook up the hoses and regulator. hoping it can stay on, but emissions may become a problem. been tryin to look for emission tips, but having a hard time. its a good thing we (CT) still have no emission checks, but that is supposed to change very very soon. who knows.
Originally posted by Berlinetta82
i could get about 400 km out of a tank. Sometimes 450 km. What's that in mpg? Doesn't look to bad but I dont know the conversion for km-mi.
400 kilometer/hour = 248.5484769 mile/hour (mph)
1 Post
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
How are you guys getting such good mileage????
My CC Qjet, which was rebuild, only gets me 200kms a tank on a weak 350!!
wtf is up?
wtf is up?
Re: who drives a computerless carbed daily driver?
im going to be running computerless in my 89 camaro. ive started the wirering or taking out the wirering the last few days. im running a 355sb with a 700r4 tranny. i still need parts to finish, but was told i need something for the tranny. if anyone knows, just let me know. thanks. here are a few pics
![](http://i34.photobucket.com/albums/d129/rayray81/downsized_0718091921.jpg)
![](http://i34.photobucket.com/albums/d129/rayray81/steeringwheel.jpg)
![](http://i34.photobucket.com/albums/d129/rayray81/paintedcamaro2.jpg)
![](http://i34.photobucket.com/albums/d129/rayray81/notchbackcamaro003.jpg)
not quite done yet. just bought the mallory distributor and msd coil and ballast resister this weekend. i was told i needed a harness for the tranny because im going computerless. not everyday you see a tunnel ram 3rd gen as a daily......lol
#42
i know right....lol. i googled something for my 89 rs and this showed up. so i figured i would restart it and hopefully get some info on my build. im uploading pics to my profile now. let me know what you think
#43
Car: '82 Z28
Dang, so I guess the first time to the dragstrip for me was back in 03 lmao
#45
Car: 1985 camaro Z/28
Engine: 305 V/8 4bbl carb
Transmission: T5 WC
Axle/Gears: 3-23 posi with 4 wheel discs
#46
mine will be a daily driver. i dont care what it gets for gas mileage. my engine builder says its around 470hp at the wheels with the tunnel ram setup
#47
Car: 1987 Trans Am
Engine: LQ9/L92
I'm working up the courage to tear out the computer harness in the next 24-48 hours. looking to go back to basics (carbed 350) for the next year before going all out (genIV). While it may become a daily driver in good weather, it will sit things out during the winter.
#48
i dont have a choice to sit out in winter. i have no heat or a/c, and i fiberglassed my dash and covered the vent holes completely. im in the middle of taking my computer harness completely out. i mean every wire not being used is going in the scrap pile
#49
Car: 1987 Trans Am
Engine: LQ9/L92
My last thirdgen was a non-cc'd carbed setup. while it worked, i never got around to putting a choke on it for those cold start days. nothing like sitting with your foot on the gas for 5-10 min just to make sure it doesn't die when you shift into gear.
#50
this is my 6th 3rd gen and this one is by far my sickest daily driver. it will be in the garage winter time. im debaiting right now as to go with a 1 piece front end, or go fiberglass fenders and hood
colton_carlson
03-08-2019 12:21 PM
