Post Your Carb'd Motor Pics
#1051
Car: 87 camaro Z28 convertible
Engine: 350 carb
Transmission: th-700r4
Axle/Gears: Posi traction 3.42 gears
Re: Post Your Carb'd Motor Pics
Ok cool. I'm upgrading my suspension and don't know what sway bar etc, to get, is qa1 a good brand ? I was looking at hotchkis, edelbrock and bmr and I don't know what size I need for the sway bar any help would be appreciated
#1052
Engine: 350 carb
Oh and what did you do for the washer fluid bottle.
#1053
quality racing brand. This is the TPI part #5226. The TBI braces will not fit on
carbed setups from what i have been told. I did have to add a shim under the
brace brackets on the towers in order to clear the strut mounts.
As far as sway bars, go with the biggest you can find... lol
#1054
The plan is to install a 1984 wiper motor i have with integrated pump. My
factory wiper motor is the old design and the water nozzles were in the way of
the STB. The newer design wiper motor has a moduler pump that is facing down
and out of the way. With the pump on the wiper motor it will allow me to install
any bottle i want. Am currently looking for a small bottle to mount in the driver
side fender. I think the current Mustang bottle will fit in the fender... LOL
#1055
Engine: 350 carb
Nice. Ok thanks I appreciate it and I hold the wiper bottle thing works out for you, and if it does I'm going to have to copy you lol
#1056
Car: 92 Camaro RS
Engine: 350 ci Carb
Transmission: 5speed
heres a pic of my carb motor. 350 crate motor (pre 1979) with 882 style heads, weiand intake, edelbrock 650 carb, 5 speed manual, other goodies
#1060
Car: 1986 camaro Sports Coupe
Engine: L31 350
Transmission: 89 700R4
Axle/Gears: 3.42 gov lock
heres mine, this is like right after i got it installed so nothing was hooked up yet.
#1061
Engine: L31 350
where is that line going from your valve cover going? distributer? can you use valve covers for a vacuum source? im sorry but this is my first motor swap and i went carbed
#1068
Car: 1979 Malibu
Engine: Blown LSx
Transmission: T56 Magnum
Axle/Gears: 9"/wavetrac/35's/3.70
Not installed yet... but soon enough. After round 2 on the dyno though. 383 sbc, 10:1 compression, Callies compstar rods, Wiseco forged pistons, Mahle rings, Custom hyd roller 0.563"/578" lift, 224/229 duration @ 0.050", 110 LSA installed at a 108 intake CL, Comp short travel lifters, Manton 5/16" .118" wall pushrods, Crower 1.6I/1.7E Enduro stainless rocker(7/16" stud) Vortec heads, CHE bronze guides, 2.02"/1.60" hollow stem valves with supporting portwork, screw in studs and guideplates, Comp 26918-16 beehives (135lb on the seat, 340lb open) GMPP eliminator single plane intake, AED 750HP-HO carb, Moroso 4 vane vacuum pump.
#1070
Car: 1979 Malibu
Engine: Blown LSx
Yah, mounting it was super easy. Less than 20 minutes, used the smog pump pulley from a tbi Chevy truck. No shimming or messing around. Pulley lined right up. Can't wait to see what it does on the dyno. Let me know when you get those pedals too!
#1072
Trying to make things look good
#1074
Car: 1992 Firebird
Engine: 383 stroker
Cut the core support (pretty sure thats what that deal is called that covers the radiator.) You can see more. Also I have parts from several cars ob this one. Mazda b2000 truck 97 Jimmy some kind of ford radiator hose and on and on. What do ya guys think?
#1075
Car: 85 Z28
Engine: 327
Anybody with a qjet actually figure out how to make the duel line routing look good?
#1077
Car: 1986 Iroc Z28 Camaro
Engine: carbed 5.7 liter 350
Transmission: th350
#1078
Car: 1982 Z28
Engine: 355
Axle/Gears: 12 Bolt
Same ole 355.. some changes in the many years since I last uploaded a pic for the thread.
#1079
thanks
Marck
#1080
I went for a clean, stock-like appearing setup in my '82 KITT car. Every wire and every hose has a purpose. All other wiring, hoses were removed, NOT cut, but removed at the source. Heater hoses re-routed for cleaner look.
On the stand:
In the car:
327 bored .60
Edelbrock 600 Manual Choke (NOTE: in the pics, shows a Holley, but the Holley wasn't worth a dime, so I switched)
Edelbrock Open Plenum Torker Intake (original Torker from the 70s)
350HP Double Hump Heads
Corvette 325HP Hydraulic Cam
Small Journal Forged Steel Crank, knife edged and balanced.
10:1 Flat top Pistons
Patriot Stainless Steel Headers
Flowmaster 40 series with 3" pipe
Painted with POR-15 Chevrolet Orange engine painting kit and I'd say the best thing you can paint an engine with. I've had the engine in the car about 6 months with NO burn-off or chipping, not even around the headers.
It's a fun little beast of an engine.
On the stand:
In the car:
327 bored .60
#1082
1 Post
Car: 1988 Camaro
Engine: 377
Transmission: TH350; Circle D 4200 converter
Axle/Gears: Ford 9"
Honestly, I love it. Looks like it rolled off the showroom floor like that. Great job.
#1084
Car: 1984 Firebird
Engine: 388 CI, Lunati Cam, Ported Heads
Transmission: 700r4 Pro-Built
Axle/Gears: 3.23 10 Bolt with mini spool
When it was FIRST dropped in. What does everyone think of my engine color choice?
#1086
Car: 86 Trans Am
Engine: Rebuilt 350 4BBL
Axle/Gears: 10 bolt rear 3.42 gears
This is my 86 Trans Am with a carbed 350
#1087
Car: 67 ******mobile
Engine: 385 Solid roller
Axle/Gears: 4.11
Nice job on the 327 that looks super sharp.
Like the stockish looking theme.
POR engine paint is great.
had mine on for 10 yrs and looks like new still.
Color is called platinum hard to see much of it
#1090
Car: 1984 Firebird
#1092
This engine is purely old school with zero computer control. It does have an HEI top mount coil vacuum advance distributor though, but that's about as technological as it gets. I even have a choke cable installed right next to the diagnostic port under the dash. That was a perfect place to put that cable in that flat spot and it looks factory and hides well. The Edelbrock 600 manual choke carb performs flawlessly on this engine.
It was a fun build and it's a fun engine. It was my dad's old engine that he raced when he was a kid and it sat outside in the elements for over 25 years with the valve covers off and I brought it back to life. I restored it as is except for the 12:1 domed pistons which I practically destroyed trying to get them out. Can't run pump gas on those anyway.
#1094
Car: 86 Trans Am
This is my 350 before it was put in my 86 Trans Am
#1095
Car: 91 camaro rs
Transmission: automatic
#1096
Car: 91 camaro rs
#1098
1 Post
Car: '85 iroc-'13 powerstroke H&S tuned
Engine: 406 sbc full roller
Transmission: t5 soon to be t56
Axle/Gears: stock
easiest way is to create a photobucket account and upload your pics to it then post the img codes on to the forum
#1099
Axle/Gears: 4.11
It may have been called Titanium its one of the two it was many yrs ago .The flash makes it look a little brigher than it is.
#1100
Car: 1984 Z28 / 2002 Z06
Engine: 350 New Crate / LS6
Transmission: T5 / M12
Axle/Gears: 3.73 / 3.42
Here's mine!
350 GM crate engine with a holley 670! Add chrome Chevy dressing kit, some goodies and it give something like this!
