Post Your Carb'd Motor Pics
#751
1 Post
Car: camaro iroc-z
Engine: 355 L98 Corvette engine
Axle/Gears: 3.27 9 bolt borg warner
Re: Post Your Carb'd Motor Pics
hahahah i always drive so fast that the cool air comming trou the engine bay!!!
just kidding!!!
i will in the future make the air filters in the front of the engine bay!
so the battery going in the trunk then i have enough space for the air filter on the passenger side!
but first i hope she runs great for now
just kidding!!!
#752
Car: 1991 Camaro Z28
Engine: 357, Canfield heads, solid roller,
Transmission: Upgraded 03 Cobra T56
Axle/Gears: 9" 3.50 gears and Detroit Locker
Heres mine. I'm changing some stuff around in the next week or two so I'll post another pic when all that is done.
#754
Car: 1986 Chevy Camaro
Engine: 6-71 Blown 355
Transmission: TH-350
Axle/Gears: Ford 9"/3.51
Heres my girl..shes a work in progress so go easy on her.
#755
Car: 91 Z28
Engine: 350 sbc 40 over 357?
Here's mine since I finally got it going again. Still plenty of clean up work to do with all the wires. I'll wait till I get it broke in. Also have to get the correct radiator hose. Someone else said that in '92 the water neck was the angled style. My '91 the water neck pointed straight forward. Will an upper hose from a '92 fit right in? Cause I see I'm about the only one using that ugly hose.
#757
heres a couple first one a buddy of mine recorded with a terrible camera, the second one was recorded with a better camera but the car was runnin terrible for some reason...bad plugs were the culprit.
vid 1: http://www.youtube.com/watch?v=Kee1Uz_iMLc
vid 2: http://www.youtube.com/watch?v=ze618DeQ7vI
#759
the pictures are 2 years old, those were actually hedman you are correct, since the pictures, ive bought Ed Quay custom headers for it there actually 1 7/8 stepped to a 2" about 1" off the block to cheat having to put the big block adapter which the guy that makes them recomended, and he ported them so its a smooth transition to the 2" so it flows perfect. my buddy put up an unauthorized description of the car..but heres the picture
best headers ive ever seen in terms of build quality and flow, i used to boost creep at high rpm to 11lbs now it sits at 7lbs right throught the rpm range, and i just put moroso spiral flow mufflers with turndowns right on the ends of the headers so it sounds ridiculous. well worth the large sum of money that they cost me, but simply put with the motor jacked up it took less than 30 seconds per side to fit in with only slight motor mount modification. worth every penny!!
#760
Car: 1978 Chevrolet impala
Engine: 350ci 300hp/356tq pace crate
Axle/Gears: 3.42 Yukon posi
http://www.youtube.com/watch?v=dnTVLNXEyH4
My carbed 305. Vortec 350 waiting for it to die to take it's place
#761
Car: 1982 Camaro
Engine: SB 427 supercharged
Transmission: Turbo 350
Axle/Gears: Ford 9in, 4:11
Also a work in progress. Card is off now having it rebuilt and powder coated blue.
#762
Car: 1982 Camaro
Whoisdabomb86 that motor is sick I love it go big or go home lol. On that note I have to go home!
#763
Car: 88 IROC-Z
Engine: 383
Axle/Gears: 4th gen 3.42posi
STB is off in this pic
http://s808.photobucket.com/albums/z...rilpics053.jpg
#764
Car: '84 Trans Am
Engine: 350 Carb
Axle/Gears: Stock but subject to change.
Mine still has to go in my car, but here it is. Just finished getting rebuilt at the machine shop.
#765
Car: 1987 Camaro IROC-Z
Engine: 350 Carbed
Transmission: Borg Warner T5
Axle/Gears: Borg Warner 9 bolt 3.73 posi
just finished up my swap this weekend and here she is, i have a lot of wires and stuff to clean up still.
with the wires all cleaned up
#768
Car: 1984 Camaro Z28
Engine: 406
Transmission: TH400 3K stall
Axle/Gears: DTS 12 bolt 3.73 eaton posi
heres my work i progress doing a bmr k member swap a long with a tranny swap 700r4 to a th400. 1 3/4" dougs headers wrapped just waiting on the lower control arms
#769
Car: 87 Iroc-z
Engine: ZZ430 clone
Transmission: 700R4 B&M shiftkit
Just finished TPI to carb conversion. Best thing i have ever did. Have a ZZ430 clone. (fastburn 385 with HOT cam and 1.6 rocker upgrade). Installed a mallory three port return regulator, Performer RPM airgap and BG 750 VAC SEC crate motor carb, tuned for this motor. Moroso 2'' drop aircleaner tucks just under the factory iroc louvered hood.
#776
Car: 89 Iroc-Z
Engine: 350/carb
Transmission: th350
The intake is a HI-TECH Torque-Link. I haven't got a chance to run it yet, still gotta brake in the new cam.
#778
I have seen those HI-Tech intakes before, only on ebay... always wanted to see how they run. I wanna see it run!!!
#780
sweet! i am usually at the nationals every year too! I made it in the dvd this past year, friday morning- the black chevy pickup with red and yellow flames
#783
Engine: 406
that is an edelbrock strut tower brace for a TBI available from jegs or summit, I have the same one.
#789
its not wood. i made a cardbpard template so when i got my piece of steel i already had my measurements. ill post a pic of the steel template under the custom front lip thread
#793
Car: 1987 BMW 325is
Engine: M20B25
Transmission: Getrag 260
Axle/Gears: 3.73 LSD
man, i have a tuned port inj. 350 and i thought it looked cool, but after i saw these pics, these look so much better in these cars i nmy opinion haha. so much less clutter and crap, and i bet the powerband doesnt DROP TO ZERO at a little after 4.5k rpm. i was thinking about upgrading to stealthram in the future, but i may have to think things over again, and consider a carb. haha. i just would want something that fits uinder the stock hood, but im sre its possible.
nice lookin pics tho, i like it
#794
Car: 1987 Z28 Camaro (T-tops)
Engine: Carb'd 305
Transmission: 700R4 (auto)
Axle/Gears: Posi / 3.27
Wow, lots of open element air cleaners in this thread. I used to run an open element but I upgraded to a spectre cold air intake. Don't have pics right now but I'll try to get em soon. CAI's make a noticable difference...
#798
Jupiter, that looks really good man! I love that you kept the AC.
#799
I want these pulleys sooo bad, but i could never find them with power steering, does anyone know if they exist? millerspeed supposedly has them but their website has been down for like a year. props though, definatley looks cool..
#800
Here is mine. Just a basic setup. I have not taken any pictures in a while. I need to snap some more. Matt i wanna check that car out sometime. I talked to you in orielys a while back. Mine is across the street at c&g
