idle screw on a Carter AFB competition series carb?
Car: 86 IROC-Z
Axle/Gears: 3.42s/posi/disc
hey i was reading a teck article and found out that instead of 700rpm my engine is suposed to idle at 500rpm and i would like to bring the idel back don to that my car has a CARTER AFB COMPETITION SERIES CARB on it ware exactley is the idle screw i see a couple that i can turn but i dont want to mess with them untill i know what they are,
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
The idle speed screw is on the throttle arm, the two idle mixture screws are in the base at the front.
Car: 86 IROC-Z
thanks alot
lol duh i should have known that when i found out it was idleing 200 rpm higher then it should be i was happy cause when i bring it back down to 500 it will sound even better with the cam i have in it while it is idleing .
theshackle
09-17-2020 08:26 AM
theshackle
03-05-2017 06:37 PM
700r4, afb, carb, carburetor, carburetors, carter, competition, compition, conversion, idle, idling, screw, series, setting, speed
