Out of the box what carb would run better
Old 03-01-2003 | 09:15 AM
e-man's Avatar
Car: 89 formula
Engine: 383
Edelbrock 750cfm 1411 or 600cfm 1406? And will be using a RPM or stealth manifold.Car specs in sig.
Old 03-01-2003 | 10:53 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
A Holley.
Old 03-01-2003 | 11:21 AM
305sbc's Avatar
Car: 1986 Irocz
Axle/Gears: 3.25:1
600 is not enough for a 383
Old 03-01-2003 | 11:24 AM
spartyon's Avatar
Car: 1986 camaro
Engine: 383 sbc
Transmission: th-400
Axle/Gears: 4th Gen 10 bolt/Detroit TrueTrac 4.
there will never be a run out of the box carb. tuning is gonna always be required.
Old 03-01-2003 | 05:56 PM
e-man's Avatar
Car: 89 formula
Engine: 383
I know tuning is required for best performance.To make a long story short Im having a problem with the wiring in my car and it wont start.I need my car for work and cant waste any more time messing with the wiring.So Im switching to a carb for now.Will either carb be close enough to letting me just bolting it on and driving?
Old 03-01-2003 | 07:10 PM
305sbc's Avatar
Car: 1986 Irocz
Axle/Gears: 3.25:1
I don't have this straight..
you were running a computer controlled carb on a 383 ???
Old 03-01-2003 | 08:02 PM
e-man's Avatar
Car: 89 formula
Engine: 383
No Im running a holley stealth ram and someting in the wiring is messed up.I dont have the time and its to cold out to be checking all the wires of the ecm.So I want to switch to a carb so I can have a running car(I need it for work).
Old 03-01-2003 | 08:18 PM
305sbc's Avatar
Car: 1986 Irocz
Axle/Gears: 3.25:1
Either Edlebrock carb will work on the engine,
but you'll need another distributor, fuel pump, throttle cable/bracket, etc.... not such a quick swap.
It may be easier to just fix the problem.
what are the symptoms?
Old 03-01-2003 | 08:58 PM
e-man's Avatar
Car: 89 formula
Engine: 383
Yah I know its not that easy but Im running out of time here.The problem is weak spark.I can't get spark at the plugs if I take a spark tester and put at the end of a wire it wont jump the gap.If I take the wire off the cap and hook up the tester to the cap it will jump the gap but not with the wires hooked up.I changed the cap,rotor,plugs,ignition module,coil,wires,pick up coil,battery,ecm even got another distributor from the scrap yard and still the same thing.I checked all the wires going to the distributor for grounds and their getting the right voltages.There is nothing left to check that I can think of or find in any books.Also I all ready have most of the parts for the swap just need the carb and manifold.
Old 03-01-2003 | 09:07 PM
Vicious Z's's Avatar
Best out of box carb
The best carb out of the box is gonna be a Demon. Some tunning may be possible with all carbs but I've had guys say they had to do no tuning to the Demon carbs after bolting on.
Old 03-02-2003 | 06:01 PM
eric17422001's Avatar
Car: 3
Engine: inboard
Transmission: underfloor
I run a Jet Performance modified Quadrajet on my 355 and it ran great out of the box, but it wasn't specifically an "out of the box" carb either - I gave them all my engine specs (Cam, compression ratio, ignition, type of intake, headers etc.) and they set it up for me. Never had a Q-jet that responsive.
Eric
Old 03-02-2003 | 11:09 PM
ben71's Avatar
Car: 1970 Chevelle
Engine: 540" BBC
Transmission: TH400
Edelbrock. They took all the fun out of tuning! My 800 cfm was dead on. After trying all sorts of tuning, my brother went back to the stock caliberation on his 750 cfm Performer. Nice carbs. I can't say I've had experience with any others though.
Ben
Old 03-02-2003 | 11:21 PM
e-man's Avatar
Car: 89 formula
Engine: 383
Thanks for the reply's I really want to go with the edelbrock because I dont want to drop alot of coin and most people say the engine will run with the edelbrock out of the box.Im doing the swap next weekend and If the car dosent run on that monday Im screwed big time.I guess Ill go with the 750cm since Im running a 383.
Old 03-02-2003 | 11:34 PM
305sbc's Avatar
Car: 1986 Irocz
Axle/Gears: 3.25:1
Here's some information about Edlebrock carbs.
http://www.cardomain.com/member_page...217306&page=26
Old 03-02-2003 | 11:50 PM
crazycamaro's Avatar
Car: 89 RS..97 RS..85 Dodge PU
Engine: 89=377,,,97=V6,,,85 PU 318
Transmission: 89=TH350,,97=T5,,85PU 4 speed
I am running a #1411 750cfm on my 355 but I had to change rods and springs out of the box,but you are running a 383 and it should be just right
Old 03-03-2003 | 05:06 AM
e-man's Avatar
Car: 89 formula
Engine: 383
Thanks guys the 1411 is what Ill get then.
Old 08-05-2003 | 01:18 PM
matt_82transam's Avatar
Car: 82 T/A
Transmission: th350 w/ high stall C.
good man, that would be my choice too
Old 08-06-2003 | 03:27 PM
I have Changed my setup since this post,Now I have the Holley 770cfm Street Advenger Carb,And Bolted it stright up and have not touched it Now its been on for 2~Months and still have'nt touched it....Not bad for a Holley
See my new set up that I have done in my Sig.
midge54
12-27-2019 05:14 PM
theshackle
03-05-2017 07:37 PM
Fast355
12-02-2016 07:33 PM
Streetstuff
Carburetors
09-07-2015 03:33 PM
86IROC112
08-17-2015 03:00 PM
Quick Reply: Out of the box what carb would run better
