new to carbs? intake question?
Ok, I am currently running a tpi system. I will be changing to carb.
I bought a used holley 750vc 4160. I is dual feed and the zinc plated version. Not trying to be stupid, but what can I do to get more performance out of it later down the road? For the record I got it for 125 bucks. The guy had ran it just at the track for 1 or 2 seasons, so it has very few miles on it and he bought it new.
Also which single plane intake with a range of 2000-2500 to 6500-7000 will fit under my stock camaro hood. I am looking at the short Team-G intakes, maybe the xcelerator, or maybe a edelbrock torkerII. Oh yeah, I will be getting dart heads, so the intake will not be for the L98 heads.
thanks for any advice. And for the record I did do a search on the inake.
Engine: LS1/LQ4
Transmission: 4L60E/4L80E
Unless you're building a race-only car, you probably want to stay away from single-plane intakes. Take a look at Stealth or RPM manifolds.
I've never heard anything good about the Torquer II from anyone but Edelbrock.
Car: 86 firebird with 98 firebird interi
Engine: pump gas 427sbc Dart Lil M 13.5:1
Transmission: Oldani TH400 w/ BTE 9" convertor
Axle/Gears: 31 spline Moser/full spool/4.11Rich
He did'nt have a stall in the sig, but if it's at least a 2800 he might be able to pull it off with a single plane, I've been toying with my ddyno and once I up the compression to 9.8:1 the single plane will up my hp & tq by 10 starting at 3500, I will be switching my 3500 stall to a 4500 for next season to get into my peak torque however.
Although, if he'd get a rpm performer based dual plane I think it'd work better as a package from low revs up to redline or shift point. Kinda contridicting myself I guess.
Car: 1986 Iroc
Engine: 454 Demon 850DP
Transmission: TH350, 3500 stall
I am running the Victor Jr. Vortech intake and an 700R4 with 2800 stall and there is no problem driving it on the street. If the Demon 850 had a choke it would be easier starting some days.
Originally posted by SlowMaro
you willing to sell the tpi setup?? if so ill buy it....if its COMPLETE wiring harness computer and all....
Originally posted by Jester
The 7530 Team G :hail: :hail: :hail:
I've got a Torker II on my car and the bad part is I hit 3K rpm and the tires go nutz......Below that it's down on TQ. I actually wanna get a Perf. RPM. so yeah...I gotta run.
