hesitation on take-off
Car: 87 IROC-Z
Engine: 350ci
First I want to say how big a help ThirdGen has been. Thank you all. Now for my question. I'm having a really bad hesitation on take-off and sudden throttle openings. Like if I'm going around a turn and I'm off the gas and then suddenly on it again the car bogs and jerks and then takes off. I'm pretty sure the problem is the pump shot. I have the orange pump cam in the #1 position. Now should I buy a more aggressive pump cam or change the shooters? BTW timming is 22 deg adv at idle and 36 deg adv at 3000rpm. Thanks for all the help.
Car: 87 IROC-Z
Engine: 350ci
The orange cam in the #1 position is the stock set up. The shooter is a .025 and I have already ordered a .028. I'm hoping this will fix the problem and I won't have to go and buy .031. Thanks for the repley. I should get the shooter on Monday or Tuesday and I"ll post the results.
Car: 87 IROC-Z
Engine: 350ci
I changed shooter to a #31 and it totally changed the for the better. Throttle response is immediate and very smooth. Thanks for all the help.
Car: 87 IROC-Z
Engine: 350ci
I do thank you for the help. It does run so much better now. I bought this car with "some assembly required" and after 6 months or so of hard work and late nights it was all worth it. BTW this is my first Third Gen and also my first V-8 and First rear wheel drive car I have ever owned.
RedLeader289
05-28-2019 01:47 PM
