Choke Light
Car: 1984 Firebird
Engine: 2.8L V6
Choke Light
My choke light is constantly on. Why? Does that mean my choke is bad or is there a fuse I should be replacing? Is there a choke fuse?
Just got a new edelbrock 600cfm electric choke. Been having problems everysince.
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
If it just showed up when you changed the carb it's probably not the alternator. Check the connections on the choke coil, the edelbrock needs a power and and ground lead.
