PCV Valve Questions????
I have an Edelbrock Performer carb (600 electric choke model) on my L03 305 on my Firebird and I need to hook up a PCV system to it. What PCV valve do I need and how do I set up the carb so it will idle smooth with the PCV? I am not the original owner so I don’t have any of the manuals that would have come with this carb.
Thanks for the help!
Car: 4
Engine: 6
Transmission: 5
Use the correct PCV valve for your engine. The carb does not care. Hook it up to a source of manifold vacuum with the right size hose barb, seems like there's a port on the throttle body on the front of those carbs you can use.
1992 Trans Am
05-10-2023 07:19 PM
