Carter 750 AFB kickdown
Old 06-06-2002 | 12:12 PM
1985_glue_factory's Avatar
So I bought this new 750 Carter carb, but it doesn't have anywhere to attach the kickdown cable. Is this something I'm gonna have to fab up, or is it a part I should be able to order from Edelbrock?
Dave
Old 06-07-2002 | 01:34 AM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
you attach the kickdown cable to the hole in the bottom of the throttle lever on the carb. You need to purchase a stud to put in the hole but it works fine. Also you need a bracket to mount the throttle cable and kickdown cable. I used a mr. gasket bracket on my car when i had a carter on there before the holley. The stud can be found in any performance magazine like jeg's or summit
RedLeader289
05-28-2019 01:47 PM
RyanJB
Members Firebirds
39
11-20-2018 03:30 PM
Briandrex
10-05-2015 06:20 AM
skinny z
Carburetors
09-29-2015 11:25 PM
makaveli09
09-15-2015 10:43 AM
Quick Reply: Carter 750 AFB kickdown
